Does anyone have an RF bridge (V2 I think: white) attached to their iHost? The latest couple of firmwares on the iHost and 3.6.0 firmware for RF bridge I’ve notice they lose connection locally. In App and Web it always works. It is just the local connection to iHost that doesn’t. Checked docker image on iHost that my devices are synchronised. Tried unsynchronising and desynchronising them. Even tried recreating one RF remote. It seems like the local connection to/from RF bridge lasts for a bit and then dies. Powercycling the RF Bridge so far has always worked for a while
the iHost is on 2.5.1
eWeLink Smart Home Docker just says “latest” when i click on info
RF Bridge is on 3.6.1
Worked for about a day. Sent limited logs to ticket number 232956
still works on eWelink Web
Oddly didn’t see anything in eWelink Smart Home logs at time recorded by eWelink web and Internet is working fine here, so shouldn’t be more than a second later. Either the RF Bridge didn’t try to reach out locally or the logs aren’t verbose enough.
I’ve just sent the ticket number (232956) my RF Bridge device ID. It always worked for a bit when I power cycled it. Not convinced the update has changed things much, but that exactly is what is happening.
The log of the buttons being pressed is on the ticket thread. From memory 23:18.52 and 23.18.57 because I had to search the eWeLink Smart Home or the logs of the time, but the verified exact times are on the thread.
