【Release Note】 Bridge-U | Zigbee Bridge Ultra Beta Version Update
If you want, I can make a video with audio so you can see and hear the problem.
Hello, thank you very much for your willingness to record a video! Our technical team has not yet been able to reproduce the issue you described, and your actual operation video will help us understand the complete process more intuitively, including the steps you take, device responses, and audio details—all of which are very helpful for identifying the root cause of the problem.
(Attachment 43950.mp4 is missing)
Hello, we were unable to receive the video file you attached (Attachment 43950.mp4). Please check whether the attachment was uploaded successfully. If necessary, you may resend the video or provide a shareable link. Thank you for your cooperation!
Someone replied to your post.
Minnie Staff of eWeLink
July 31
(attachments)
July 31
Hello, thank you very much for taking the time to record and send the operation video! Our technical team will analyze it together with the logs you previously provided. Thank you again for your patience and cooperation!
Hello, thank you for your patience. Our technical team has analyzed the logs you submitted and identified the root cause of the issue:
When there are a large number of sub-devices connected to the system and the “Arming Delay” feature is enabled, during the process of switching to or activating another security mode, the delay timer from the previous arming session is not properly cleared. This causes the timer to continue running in the background, resulting in the gateway emitting a persistent beeping sound.
We expect to fix this issue in the new firmware release scheduled for early September. In the meantime, we recommend that you temporarily disable the “Arming Delay” function, which should effectively reduce or eliminate the continuous beeping.
Thank you for your understanding and support. If you have any further questions, please feel free to contact us.
From Friday 07.08.2026 i have new 3.5.0 version. Any changes from 3.30 and 3.4.0?
Hello, regarding the changes between versions 3.30 and 3.4.0, let me first explain our version numbering rules so that you have a clearer understanding of how versions relate to each other:
Our version number format is: MAJOR.MINOR.PATCH (Major.Minor.Patch)
The distinction between Stable and Beta versions is based on the MINOR number:
  • If the MINOR number is even, it is a Stable version.
  • If the MINOR number is odd, it is a Beta version.
The version you are currently using is V3.5.0, where the MINOR number is 5 (odd). This means you are on the Beta release track. This is a normal part of our version iteration process, and you have not “skipped” version 3.4.0.
So what was changed from 3.3.0 to 3.5.0?
Version 3.5.0 (2026/07/09)
New Features:
1.Expanded Device Compatibility:** Added support for the following Zigbee devices:
  • SONOFF SNZB-09P Zigbee indoor siren
  • SONOFF TRV-ZBT Zigbee + Bluetooth thermostatic radiator valve
  • SONOFF MINI-ZB1GS single-channel Zigbee smart switch
    2.Matter Bridge Update:Now supports syncing energy metering data from connected Zigbee devices to Matter-enabled platforms, including total export energy and total consumption.
Optimizations:
1.Water Valve Unit Options: Added imperial gallon as a volume unit option for the following SONOFF smart water valves:
  • Single-channel valves: SWV-ZNU / SWV-ZNE / SWV-ZFU / SWV-ZFE
  • Dual-channel valves: SWV-ZF2U / SWV-ZF2E
    2.Expanded Local Web Portal Support:** Added a quick access to the ZBBridge-U device compatibility list.
Bug Fix:
Mapping issue:Fixed incorrect device type mapping for Giex GX03 Zigbee dual-channel water valves.
