Beta Version 3.11.0 (2026/10/12)
New Features:
- Added support for the following Zigbee devices:
- SONOFF SNZT-04P Zigbee door/window sensor
- SONOFF SNZT-03P Zigbee motion sensor
- SONOFF ZBM5-1C-86/120 Zigbee smart wall switch
- SONOFF ZBM5-2C-86/120 Zigbee smart wall switch
- SONOFF ZBM5-3C-86/120 Zigbee smart wall switch
- Added five selectable alarm sounds configurable for the SONOFF SNZB-09P indoor siren.
Optimizations
- Improved the process for entering pairing mode and performing a factory reset on the SONOFF SNZB-02B.
- Updated the default temperature and humidity reporting thresholds for SONOFF SNZB-02WD and SNZB-02LD.
- External switch events from SONOFF ZBMINIR2 can now be used as scene triggers.
- SONOFF SNZB-02DR2 can now use two external sensors, with temperature and humidity readings from both shown on its display and in the eWeLink App.
- Turbo Mode is now available in the Local Web Portal to maximize the Zigbee module’s transmit power and help improve signal strength.
- Added support for the Tuya T2-Z62 smart fan switch, with supported controls exposed to Matter-enabled platforms via Matter Bridge.
Bug Fixes:
- Resolved an issue preventing a SONOFF TR-WGZBA thermostat panel from working with two SONOFF TRV-ZBT thermostatic radiator valves at the same time.
- Fixed an issue where the SONOFF TR-WGZBA could incorrectly display 0°C when linked to a SONOFF SNZB-02DR2.
- Fixed an issue where the operating mode and target temperature for the Atlantic Group Interface Naviclim (GW003-AS-IN-TE-FC) were not displayed in the eWeLink App.
- Fixed an issue where the alarm status of the SONOFF SNZB-09P could fail to sync after the bridge recovered from a power outage, leaving the alarm controls in the eWeLink App unresponsive.
- Fixed an issue where sub-devices could disappear or lose their names in the eWeLink App after an offline ZBBridge-U was deleted and re-added to the same account.
- Fixed an issue where the thermostat mode and operating status of the MOES BHT-002 were not displayed in the eWeLink App.
v3.9.0 what's new
Beta Version 3.9.0 (2026/09/10)
Expanded Device Compatibility:
- Added support for SONOFF TP-WGZBA Zigbee/ Bluetooth dual-mode thermostat panel.
Matter Bridge Updates:
- Added support for syncing the following Matter-supported device types to Matter-enabled platforms via Matter Bridge:
- Dimmable Plug-in Unit
- Pressure Sensor
- Added support for exposing additional Air Quality Sensor measurements via Matter Bridge:
- Formaldehyde concentration
- Nitrogen dioxide concentration
- Ozone concentration
- PM1 concentration
- PM10 concentration
- Radon concentration
- Expanded Boolean State Configuration cluster support for:
- Occupancy Sensors now support sensitivity adjustment.
- Water Leak Detectors now support enabling or disabling tamper alerts.
Optimizations:
- Changed Matter Bridge mapping for multi-function devices to use multiple endpoints instead of compose, improving device compatibility.
- SONOFF BASIC-ZB1GSP now supports bidirectional energy monitoring, with exported energy data available in history graphs.
- SONOFF SNZB-02UL can now use SNZB-02D, SNZB-02P, SNZB-02WD, SNZB-02LD, SNZB-02DR2, SNZB-02B, SNZB-02M, and other SNZB-02UL devices as external sensors, providing more accurate room temperature measurements.
- The Ethernet MAC address is now available in the Local Web Portal.
- SONOFF SNZB-03PR2 can now be used as a Smart Security alarm trigger.
- Automations now run immediately after creation or editing if their sub-device trigger conditions are already met.
- Updated BTHome device mappings over MQTT to represent supported capabilities more accurately.
- Optimized status cache handling for third-party sirens that do not automatically report status data.
Bug Fixes:
- Fixed an issue where ZBBridge-U could continue beeping when delayed arming was enabled with more than three sub-devices.
- Fixed an issue where Zigbee device syncing to Home Assistant could fail after MQTT recovered from an initial connection failure.
- Fixed an issue where SONOFF SNZB-09P was shown as “Unsupported” and could not be exposed to Matter-enabled platforms via Matter Bridge.
v3.7.0 what's new
Beta Version 3.7.0 (2026/08/10)
New Features:
- Local Web Portal Enhancements
- Added access to the Zigbee2MQTT web interface for monitoring Zigbee devices, adjusting parameters, and accessing advanced settings.
- Added support for the following Zigbee device types:
- Siren
- Water Valve
- Flow Sensor
- Rain Sensor
- Soil Sensor
- Air Purifier
- Expanded the range of Zigbee device types that can be synced to Matter-enabled platforms via Matter Bridge:
- Siren
- Flow Sensor
- Rain Sensor
- Soil Sensor
- Air Purifier
- Matter Bridge Update: eWeLink-linked cameras on the same local network as ZBBridge-U can now be bridged to Matter-enabled platforms for live video viewing.
- Expanded Device Compatibility
Added support for the following Zigbee devices:- SONOFF S61SZBTPB US-type Zigbee smart plug
- SONOFF MINI-ZB1GS single-channel Zigbee smart switch
- Bridge Firmware Recovery Authentication: Access now requires the Local Web Portal password.
Optimizations:
- SONOFF SNZB-02UL can now serve as an external sensor for SONOFF SNZB-02DR2 or SONOFF TRVZB, providing more accurate room temperature measurements.
Bug Fixes:
- Fixed an issue that prevented the following SONOFF Zigbee/Bluetooth dual-mode devices from being added through the Local Web Portal when no eWeLink account was linked:
- Smart Water Valves: SWV-ZNU / SWV-ZNE / SWV-ZF2U / SWV-ZF2E
- Thermostatic Radiator Valve: TRV-ZBT
- Smart Switches: MINI-ZB1GS / MINI-ZB1GSP
- Power Meter: MINI-ZB1GP
- Fixed an issue where Bridge Firmware Recovery could incorrectly report that the Zigbee module had failed to start.
- Fixed an issue where some channels were missing from the Zigbee channel list.
- Fixed an issue that could cause OTA updates for SONOFF MINI-ZB1GSP to fail.
- Fixed an incorrect device-type mapping that identified Third Reality soil moisture sensors as temperature sensors, preventing soil moisture readings from being reported.
- Fixed an issue where room assignments, accessory names, scenes, and automations for SONOFF TRVs in Apple Home could be lost after a ZBBridge-U restart.
- Fixed an issue where color controls were unavailable on Matter-enabled platforms for GLEDOPTO GL-C_202P controllers that support color control but not color temperature control.
v3.5.0 what's new
Beta Version 3.5.0 (2026/07/08)
New Features:
- Expanded Device Compatibility: Added support for the following Zigbee devices:
- SONOFF SNZB-09P Zigbee indoor siren
- SONOFF TRV-ZBT Zigbee + Bluetooth thermostatic radiator valve
- Matter Bridge Update: Now supports syncing energy metering data from connected Zigbee devices to Matter-enabled platforms, including total export energy and total consumption.
Optimizations:
- Water Valve Unit Options: Added imperial gallon as a volume unit option for the following SONOFF smart water valves:
- Single-channel valves: SWV-ZNU / SWV-ZNE / SWV-ZFU / SWV-ZFE
- Dual-channel valves: SWV-ZF2U / SWV-ZF2E
- Expanded Local Web Portal Support: Added a quick access to the ZBBridge-U device compatibility list.
Bug Fix:
- Mapping issue: Fixed incorrect device type mapping for Giex GX03 Zigbee dual-channel water valves.
v3.3.0 what's new
Beta Version 3.3.0 (2026/06/26)
New Features:
- Expanded Device Compatibility: Added support for SONOFF MINI-ZB1GP / MINI-ZB1GSP single-channel Zigbee smart switches with electricity monitoring.
- Home Assistant Audio Automations: Added support for playing audio from Home Assistant through the ZBBridge-U speaker, enabling audio-based automations.
- Expanded Matter Hub Compatibility: Now supports syncing bridged dimmable lights along with the Matter Bridge when it is added to ZBBridge-U.
Optimizations:
- Firmware Recovery Improvement: Improved the factory reset logic for better performance and stability.
- Matter Bridge Update: Now supports syncing Boost Mode from SONOFF TRVZB to third-party Matter platforms.
- Matter Sync: More Wi-Fi devices can now be synced to Matter-enabled platforms, including:
- CoolKit CK-BL602-TC-01 (216) gate operator
- CoolKit NON-OTA-GL (272) eWeLink thermo plugin
Bug Fix:
- Fixed an issue where SONOFF SNZB-02M could incorrectly show air pressure comfort as out of range when no air pressure comfort range was configured.
v3.1.0 what's new
Beta Version 3.1.0 (2026/06/09)
- Added support for SONOFF SNZB-03PR2 Zigbee motion sensor with illuminance reporting.
Optimizations:
- SONOFF SNZB-02DR2 now supports using SONOFF SNZB-02M and SNZB-02B as external sensors for more accurate room temperature readings.
- Improved support for metering capabilities on Zigbee single-channel smart plugs with energy monitoring.
