v1.0.0(2026/06/27)
Expanded Device Compatibility
- SONOFF Hydro ONE Zigbee Smart Water Valves: Added support for SWV-ZFU / SWV-ZFE and SWV-ZNU / SWV-ZNE models.
- SONOFF Hydro One Dual-Channel Smart Water Valves: Added support for SWV-ZF2U / SWV-ZF2E.
- SONOFF SNZB-06P24: Added support for the 24 GHz presence sensor.
- SONOFF BASIC-ZB1GSP: Added support for the single-channel smart plug with energy monitoring.
- SONOFF SNZB-02M: Added support for the temperature, humidity, and air pressure sensor.
- ZIGBEE_SMOKE_SENSOR: Added support for smoke detectors.
- SONOFF SNZB-03PR2: Added support for the Zigbee motion sensor with illuminance reporting.
- SONOFF MINI-ZB1GP / MINI-ZB1GSP: Added support for single-channel Zigbee smart switches with electricity monitoring.
- SONOFF MINI-ZBRBS: Added an option to configure extra travel time to ensure blinds fully open and close during manual calibration.
- SONOFF MINI-ZB2GS: Added stepping control support, allowing external switch press actions to cycle through a predefined sequence of relay states for flexible multi-state control.
- SONOFF TRVZB:
- Added Adaptive Mode to dynamically adjust based on environmental changes for more stable and comfortable room temperature.
- Added local scene support.
New Features in Bridge-M
- Smart Security for Matter: Arming/disarming can now be exposed to Matter-enabled platforms, mapping as On/Off toggles via Matter Bridge.
- Channel Detection: Added support for detecting the health of Zigbee and Wi-Fi channels, and supports switching Zigbee channels.
- Startup Sound Volume Control: Adjusting startup sound volume is now available in the Settings page.
- Home Assistant Integration Enhancement: Firmware updates can now be checked and installed directly from Home Assistant for Bridge-M and its sub-devices synced to Home Assistant.
- WeLink-Remote Sub-devices Support: Bridge-M now supports acting as an eWeLink-Remote gateway. Supported sub-devices include:
- SONOFF R5
- SONOFF R5W
- SONOFF S-Mate
- SONOFF S-MateR2
- BTHome Integration: Added support for discovering eligible BTHome devices via Bluetooth LE advertising and exposing supported BTHome data to Matter-enabled platforms through Matter Bridge.
Bridge-M Feature Optimizations
- Matter SDK Updated: The built-in Matter Bridge now runs on Matter spec V1.5.0 for better compatibility.
- Zigbee Compatibility: Updated Zigbee2MQTT to v2.9.1 to expand Zigbee sub-device compatibility.
- Firmware Upgrade: Updated the Zigbee module firmware to v8.0.2 to improve Zigbee connection stability.
- Optimized Pairing: Improved Bluetooth pairing and BLE broadcast scanning performance, enhancing device discovery speed and pairing success rate.
- Offline Detection: Optimized Zigbee offline detection logic to identify device disconnections faster and improve control reliability.
- Home Assistant Integration Enhancements:
- Smart Security: Optimized the Smart Security entity to a “Select” type for more intuitive control, while remaining backward compatible with existing “Switch” entities.
- Naming: Zigbee devices now display as “brand + model” when synced to Home Assistant.
- Authentication: Entity data is now fetched only after Home Assistant authentication succeeds.
- Entity Icons: Home Assistant synced entities can now display the correct icons for easier recognition.
- Matter Sync: More Wi-Fi devices can now be synced to Matter-enabled platforms, including:
- SONOFF MINI-2GS
- SONOFF SAWF-07P / SAWF-08P
- SONOFF MINI-DIM
- SONOFF BASIC-1GS
- SONOFF MINI-RBS
- SONOFF S61STPF / S41STPB
- CoolKit CK-BL602-SWP1-02 (262)
- CoolKit CK-BL602-W102SW18-01 (226)
- CoolKit CK-BL602-TC-01 (216) gate operator
- CoolKit NON-OTA-GL (272) eWeLink thermo plugin
Device Function Optimizations
- Temperature Source: SONOFF TRVZB now supports using SONOFF SNZB-02B as an external temperature source.
- Security Triggers: Added “Tamper Alert” as a Smart Security alarm trigger for SONOFF SNZB-04P and SONOFF SNZB-04PR2.
- External Sensors: SONOFF SNZB-02DR2 now supports using SONOFF SNZB-02M and SNZB-02B as external sensors for more accurate room temperature readings.
- Metering Data Display: Optimized the display of metering data for the Zigbee power metering plug (CK-TLSR8258-MSW-02).
Bridge-M Functionality Fixes
- Fixed the device status reporting mechanism for battery-powered Zigbee sub-devices, reducing occurrences of incorrect offline status.
- Fixed an issue where the Zigbee sub-device version was displayed incorrectly on the local webpage after a Zigbee sub-device upgrade.
- Resolved the issue where the local webpage still showed that an update was available for the OTA sub-device in Home Assistant.
- Fixed an issue where Zigbee-related functions became unavailable during gateway startup due to occasional abnormal crashes of the Zigbee module.
- Fixed an issue where syncing the gateway to Alexa via Matter Bridge would fail.
- Fixed an issue where, after connecting Home Assistant curtain devices to third-party Matter platforms, the switch state in the app appeared opposite to the actual physical state.
- Fixed an issue where batch adding devices resulted in some devices failing to control.
- Fixed an issue where writing coordinator device information failed during Zigbee startup, causing gateway startup failure.
- Fixed an issue where the reconnection timer was not cleared after a successful Home Assistant MQTT connection was disconnected.
- Fixed Zigbee channel scanning time and resolved the issue of Zigbee channel scanning failure in the App.
Device Function Fixes
- Fixed a data scaling issue where temperature and humidity values for Tuya TS0201 sensors were displayed incorrectly.
- Fixed an issue where IKEA smart curtains could fail to respond to controls in the eWeLink App.
- Fixed the issue of scenes not triggering on SNZB-02P and SNZB-06P devices.
- Fixed an issue where TRVZB would switch to Boost mode after restarting Bridge-M in manual mode.
- Fixed an issue where control failed after MINI-ZBDIM was added to the Matter platform via Matter Bridge.
- Fixed an issue where temperature readings from TRVs synced via ZBBridge-U could not display as expected on NSPanel Pro.
- Fixed an issue where the comfort level for SONOFF SNZB-02P, SONOFF SNZB-02D, and SONOFF SNZB-02DR2 could be displayed incorrectly.
- Fixed an issue where humidity was not shown in the eWeLink App for Tuya TS0201 sensors.
- Fixed an issue where SONOFF SNZB-02M could incorrectly show air pressure comfort as out of range when no air pressure comfort range was configured.
- Fixed data continuity for SWV-ZN / SWV-ZF devices when switching between Zigbee and Bluetooth modes.
