Good morning,
Regarding compatible zigbee devices, there are:
“TuyaTS0002 2 Gang”
I have been able to correctly synchronize this device on ihost, however when I click on one of the gangs from ihost, both are activated automatically, not the one I clicked on. Is it possible or is there an action/possibility to correct that only the gang on which I click is activated/deactivated?
aibridge-zigbee/zgateways.log
mqtt_pub : topic: zigbee/system/discovering, payload: {“discovering”:true,“countdown”:180,“reason”:“Discover request”}, property: reqClientId:api, reqSequence:1705395059828
mqtt_pub : topic: zigbee/system/discovered, payload: {“manufacturer”:“_TZ3000_ptjcjise”,“model”:“TS0002”,“serialNumber”:“a4c138be90cc93d7”,“firmwareVersion”:“5.2”,“displayCategory”:“switch”,“linkLayerType”:“Zigbee-ZR”,“capabilities”:[{“capability”:“power”,“permission”:“readWrite”},{“capability”:“toggle”,“permission”:“readWrite”,“name”:“1”},{“capability”:“toggle”,“permission”:“readWrite”,“name”:“2”},{“capability”:“rssi”,“permission”:“read”}]}, property: reqClientId:zigbee, reqSequence:1705395074102
mqtt_pub : topic: zigbee/device/a4c138be90cc93d7/information, payload: {“manufacturer”:“_TZ3000_ptjcjise”,“model”:“TS0002”,“serialNumber”:“a4c138be90cc93d7”,“firmwareVersion”:“5.2”,“displayCategory”:“switch”,“linkLayerType”:“Zigbee-ZR”,“capabilities”:[{“capability”:“power”,“permission”:“readWrite”},{“capability”:“toggle”,“permission”:“readWrite”,“name”:“1”},{“capability”:“toggle”,“permission”:“readWrite”,“name”:“2”},{“capability”:“rssi”,“permission”:“read”}]}, property: reqClientId:zigbee, reqSequence:1705395074104
mqtt_pub : topic: zigbee/device/a4c138be90cc93d7/updated/toggle/1, payload: {“toggleState”:“on”}, property: reqClientId:zigbee, reqSequence:1705395074108
mqtt_pub : topic: zigbee/device/a4c138be90cc93d7/updated/toggle/2, payload: {“toggleState”:“off”}, property: reqClientId:zigbee, reqSequence:1705395074109
mqtt_pub : topic: zigbee/device/a4c138be90cc93d7/updated/rssi, payload: {“rssi”:-50}, property: reqClientId:zigbee, reqSequence:1705395074109
mqtt_pub : topic: zigbee/device/a4c138be90cc93d7/availability, payload: {“online”:true}, property: reqClientId:zigbee, reqSequence:1705395074110
mqtt_sub : topic: zigbee/system/discover, payload: {“discover”:false}, property: reqClientId:api, reqSequence:1705395091649
mqtt_pub : topic: zigbee/system/discovering, payload: {“discovering”:false,“countdown”:0,“reason”:“Discover request”}, property: reqClientId:api, reqSequence:1705395091649
mqtt_sub : topic: zigbee/device/a4c138be90cc93d7/update/toggle/1, payload: {“toggleState”:“off”}, property: reqClientId:api, reqSequence:1705395103161
mqtt_pub : topic: zigbee/device/a4c138be90cc93d7/update-result/toggle/1, payload: {“received”:true,“toggleState”:“off”}, property: reqClientId:api, reqSequence:1705395103161
mqtt_pub : topic: zigbee/device/a4c138be90cc93d7/updated/toggle/1, payload: {“toggleState”:“off”}, property: reqClientId:zigbee, reqSequence:1705395103545
mqtt_pub : topic: zigbee/device/a4c138be90cc93d7/updated/rssi, payload: {“rssi”:-51}, property: reqClientId:zigbee, reqSequence:1705395103546
mqtt_pub : topic: zigbee/device/a4c138be90cc93d7/updated/toggle/2, payload: {“toggleState”:“off”}, property: reqClientId:zigbee, reqSequence:1705395103738
mqtt_pub : topic: zigbee/device/a4c138be90cc93d7/updated/rssi, payload: {“rssi”:-49}, property: reqClientId:zigbee, reqSequence:1705395103739
Thank you so much
