NsPanelPro Status bar display problem
Ricky11
11 min
I recently started using the new version 4.4.6 of NsPanelPro, which natively integrates F-Droid, allowing me to install the Home Assistant app.
Although there are still a few minor bugs to fix, this new version is convenient because you can switch between the Sonoff app, Home Assistant, or any other app available in F-Droid using the status bar at the bottom of the screen. My question concerns this status bar… when I display Home Assistant, which is in dark mode by default, the status bar turns white, making the icons difficult to read, and I can’t figure out how to keep it on a black background!
Hi, I have verified according to your settings. The bottom navigation bar is actually transparent, and it will display the corresponding color based on the background color. As for HomeAssistant running on NSPanelPro, it actually opens a WebView browser. After modifying the theme color in HomeAssistant, it does not change the theme color of the entire browser. Therefore, the browser’s tab status bar remains its original color, and the mapped navigation bar also shows the corresponding color (you can refer to a desktop browser: after changing the HA theme color, the web content will adopt that theme color, but the top part of the browser remains unchanged).
