NSPanelPro Smart Security Integration
Hi there,
Untill few weeks ago i had an automatic scene in my NSPanelPro120, so when an alarm was trigered, some of my Ultimate TX wall switch where acting as a siren.
Now seems that when an alarm is trigered, the scene doesnt activate and even in the log i cant see it.
Since also the new two cameras model, CAM-B1P and Pan-Tilt 2, are available, i think can be a good idea to have a direct intregration of this devices in the Smart Security.
For example to use the Ultimate TX as a siren, or if i set AWAY MODE, to activate detection on all cameras and deactivate when the alarm is unarmed.
Thankyou
Thank you very much for using NSPanel Pro. We are sincerely appreciate your valuable feedback.
We were busy rolling out V4.x App for NSPanel Pro. This version has been completely rewritten in Kotlin and it should provide much better performance and stability.
We will work on your suggestion ASAP.
@LMX is our new product manager in charge of NSPanel Pro. He and I will keep you posted on this feature.
Hi, I would like to further confirm your needs. Do you want to be able to control the motion detection function of the CAM-B1P and Pan-Tilt 2 cameras when the Away mode of the smart security is turned on/off, or when the alarm is triggered/cleared in Away mode?
Goodmorning and thankyou so much for your replay.
Yes, as i mention in the post, the idea Is to be able to Control also the functionality of wifi devices ( TX ultimate Wall switch, Camera B1P and others) in the smart Security, for example:
  • Enable motion detection when Away mode or Sleep mode are on;
  • when an alarm Is triggered Enable siren from camera TX wall switch.
Is Just an idea, i think NSPanelPro.has a lot of potential in this.
A lot of my friend wanted It After they saw from me, and i installed until now 10 system.
We are sincerely appreciate your valuable feedback.We will work on your suggestion ASAP.I will keep you posted on this feature.
Could you please confirm if you are still experiencing this issue with your current version? If so, please reproduce the scenario once (let it trigger but not execute), then submit logs via Settings > About on your device. After submission, send your Device ID directly to me. We will investigate as soon as we receive it.
