@ward I can reproduce the problem in my laptop if I set Firefox to use HTTPS-Only mode:
But what I don’t understand is why this problem is happening on NSPanel Pro. It seems it’s trying to access by HTTPS too.
yea, it’s kinda strange, either me nor the dev team can re-produce the issue on NSPro.
Feedback sent from NSPanel Pro
Please, check the log received at 9:37am (GMT 0)
I accessed CAST from NSPanel Pro at these times below, always receiving the same error on the weather tile.
How is the performance of home assistant in web shortcuts in v3.8.0 now?
if there are still problems, when is the next fix update coming?
I’m planning to buy multiple of them.
@nathanflores888 Thank you very much for using NSPanel Pro.
We are phased-releasing v4.0.x firmware for NSPanel Pro right now. v4.0.x firmware comes with built-in F-Droid Appstore. Users can install Home Assistant App (and other open source Apps) from F-Droid.
v4.0.x firmware has also been completely rewritten using Android’s native programming language Kotlin which provides much better performace and responsiveness (of the UI interaction).
It would be great for us if you could try out the v4.0.x firmware.
Hi there! Based on valuable user feedback, we’ve just released the optimized v4.0.7 today, which includes the following fixes and improvements:
Added support for MINI-RBS
Fixed remote temperature/humidity source issue for TRV
Resolved control abnormalities with some third-party Zigbee devices
Fixed device card list display issues in certain time zones
Improved UI display for temperature and humidity devices
*After upgrading, please verify that both Settings → APP Version and OS Version show 4.0.7. If not, please continue the upgrade process.
If you encounter any issues, feel free to report them in this post at any time. We will address your concerns promptly or release a fix as needed. Thank you for your continued support of NSPanel Pro!
