NSPanel (non-pro) missing reverse option
Hello
I bought an NSPanel and an S-Mate2 Extreme to substitute two light switches in a room (the lights could be turned on or off from 2 different locations using SPDT switches).
My idea was to substitute one of the light switches with the NSPanel and substitute the other with the S-Mate2 creating a scene so when I clicked on the S-Mate the NSPanel would change its state.
Regretably, NSPanel doesn’t have the “REVERSE” option when creating scenes (check uploaded image). Therefore, I can only create a scene that will turn ON or OFF one of the channels of the NSPanel each time I click on the S-Mate. I cannot create a scene that will turn it on if its off or off if its on (the REVERSE option that most switches do have).
I also discovered that the S-Mate2 doesn’t allow you to create a scene with two conditions (ie. If I click channel 1 AND NSPanel Channel 1 is ON, then turn off and viceversa). Most other switches allow scenes with more than one condition, but the S-Mate2 only allows one condition (press, long press or double press).
I think it would be trivial to add “REVERSE” to NSPanel switches, as it’s already been implemented on other smart switches.
Just to clarify: are you using the original NSPanel or the NSPanel Pro? The distinction matters here, because eWeLink-Remote support differs between the two models. I also remember Reverse being available in scenes with NSPanel Pro, so I’d like to make sure we’re talking about the same device.
I’m using the original NSPanel and not the pro version.
Thanks for clarifying. One more question: which device is your S-Mate2 paired with as its eWeLink-Remote gateway? The original NSPanel isn’t listed as an eWeLink-Remote gateway, so I’m curious how you’ve set up the connection between the S-Mate2 and the NSPanel.
It’s linked to the NSPanel. It does support remote control.
Sorry for the confusion earlier. I was relying on the official S-Mate2 compatibility information, which lists NSPanel Pro but not the original NSPanel. Your screenshot makes it clear that your S-Mate2 is linked to the original NSPanel, so I was wrong to question your setup.
One question that might help clarify the issue: what type of wall switch are you using with the S-Mate2: a latching rocker switch or a momentary push button? And is the S-Mate2 set to Rocker Switch Mode or Momentary Switch Mode?
I’m asking because these modes may handle input changes differently (edge-triggered versus pulse-triggered events), which could be relevant to the behaviour you’re seeing.
The S-Mate is working properly as it correctly registers switch presses. I’m using a latching rocker switch and the S-mate is set to rocker mode.
An option I’ve been thinking about is changing the switch to a momentary one, which would allow me to have short press and long press and set short press for on and long press for off. Although it would work it’s a ridiculous solution and every other Sonoff Smart Switch allows the option “Reverse” while creating a scene.
I think it’s a very easy fix. Please Ewelink/Sonoff update this for the NSPanel.
