I have noticed an issue with the NodOn SEM-4-1-00 Zigbee energy meter** when using it with SONOFF iHost and CUBE Cast.
The device is correctly paired with iHost and works properly through the iHost web interface (ihost.local), where I can see the following real-time measurements:
Voltage (V): Displayed correctly.
Current (A): Displayed correctly.
Active Power (W): Displayed correctly.
Energy consumption: Available through the device interface.
However, when I add the same device to CUBE Cast, the voltage, current and power measurements are not displayed correctly. Instead, CUBE Cast shows 0 A and 0 W, even when iHost is reporting actual consumption.
This suggests that the device is communicating correctly with iHost, but some of its measurement values are not being properly transferred to or displayed in CUBE Cast.
My questions are:
Is the NodOn SEM-4-1-00 fully supported by CUBE Cast?
Is this a known bug related to the display or synchronization of energy measurements?
Are there any plans to fix this issue in a future iHost or CUBE Cast update?
I have attached a screenshot showing the difference between both interfaces.
Thank you for your feedback. We apologize for any inconvenience this may have caused. We are currently investigating the issue and will keep you updated as soon as there is any progress.
Hello @sintoxx, is the inaccurate current/power reading on the CAST side a long-standing issue, or does it only occur occasionally as a temporary inconsistency?
This is a persistent issue, not an occasional or temporary inconsistency.
The SONOFF iHost web interface (ihost.local) consistently receives and displays the correct voltage, current, and power measurements from the NodOn SEM-4-1-00.
However, CUBE Cast consistently displays 0 A and 0 W, even though the correct values are available in iHost. The voltage reading is displayed correctly in both interfaces.
The issue is permanent and does not resolve itself over time. It appears to be related specifically to how CUBE Cast retrieves or displays the current and power values, rather than a communication problem between the device and iHost.
Thank you for your detailed feedback. Please follow the attached guide to send me your log link and the device ID of the NodOn SEM-4-1-00 via private message so that we can locate the issue more quickly.
