New Bluetooth device detected in Home Assistant
I’ve noticed that my Home Assistant instance (running on iHost) has found a new Bluetooth device. I think it is the bluetooth chip of the iHost, but I’m not sure.
I’m also not sure which update has triggered it : the home assistant docker image or the 1.9.1 ihost.
Still, the integration doesn’t work yet, it seems that the Dbus service isn’t yet implemented.
Can someone confirm the behaviour ?
Is there a way to know the Mac adress of the Bluetooth chip of the iHost ?
Is there a plan to enable Bluetooth on iHost sooner or later ?
Can anyone from dev team confirm if Bluetooth can be configured to work in docker HA?
As previous post mentions HA does find a Bluetooth chip but misses some config. See attached.
Cheers,
Istvan
I have same problem. Do you have any solve?
