Need More Scene Trigger
I need some
If trigger
Offline device
Online device
Location
Enter or
Leave
Thanks for the suggestion!
The geo-related trigger is already in consideration.
As for the device availability status trigger, could you please describe your use case?
I had TV connect with L3 led strip to 2a usb port
And I had furniture that connect via usb adaptor on it.
Then I had add old legacy wifi from them, my ruijie is not compatible with it.
Then after successful connect with wifi I can used scene to control them both.
But when TV of and make L3 usb offline then it did not trigger second L3 via usb plug to off
When I turn TV on it did not trigger L3 on furniture on.
For temporary fix this issue
I had to connect L3 with Home Theatre usb in furniture and link them on by hdmi CEC anynet or simple link.
But it did not make scene to other L3 at groove ceiling to set same atmosphere by just click tv remote and trigger room to change all L3 in scene at setup.
Geo related trigger is the most missed by me compared to Tuya infrastructure. I need to disable heating when I am not in my summerhouse. Save electricity bill and prevent possible fire. For now I had to add Tuya power socket in pair with TH Origin switch with hum/temp sensor.
For gate arrived opening and closed.
Or
Arm and disarm houses.
Some app like alexa is slowly to responded or Circle area to triggers is to o big.
https://sequematic.com
Hey there! I’d really appreciate it if you could add a feature that makes the device reset itself after going offline so it can get back online again. Thanks!
Can you help, I can’t think of on how to trigger geo location with it? There is not even a app for it to track geo location.
It depends on what exactly you want to achieve?
Perhaps I misunderstood “geo” I meant “Weather” as the trigger.
Write down precisely and clearly the principle of action you want to achieve.
I have been using MacroDroid for similar details for a long time:
It can be correlated with Sonoff devices via Webhooks, and it is practically free (some symbolic one-time fee if you want to avoid minor inconveniences).
