Maximum Brightness setting (for D1)
So the ewelink app has a nise setting to set the minimun to where the brightness slider can go to when using a dimmer ( D1 in my case)
This will eliminate dead space or unsupported vrightness levels for you setup.
Question is , is there a way to limit the max brightness? As my bulbs goes down to 1% brightness perfectly, butbbetween 70 and 100% there is nothing happening. I would like to “remove” the top 30%.
Any suggestions would be appreciated .
Any help guys?
