Set the brightness of a control device
I want to set the brightness for a control device. now you can only set 1 number between 0 and 100.
i want to sent a json message to the control device end adjust de brightness dynamicly
Regards Rick
Hey
Do you mind telling us more about your case?
In node-red i register a new light device. That device should control 3 other light
cube devices. Because they are actually 1 lamp.
on/off via that registered new node-red device works fine. But the brightness not.
        "id": "f6f2187d.f17ca8",
        "type": "tab",
        "label": "Flow 1",
        "disabled": false,
        "info": ""
        "id": "682221649ae351c2",
        "type": "control-device",
        "z": "f6f2187d.f17ca8",
        "name": "Paallamp Off",
        "server": "47b82da33cd7c32b",
        "list": "{\"type\":\"light\",\"deviceId\":\"984db14d-dd32-47f1-8fe5-ce022f90f545\",\"light\":{\"power\":\"off\",\"brightness\":\"\",\"type\":\"color-temperature\",\"colorOrTemp\":\"\",\"hslStr\":\"\"}}",
        "category": "light",
        "device": "984db14d-dd32-47f1-8fe5-ce022f90f545",
        "action": "",
        "x": 810,
        "y": 1040,
        "wires": [
        "id": "9c02cfa3137da37a",
        "type": "bigtimer",
        "outtopic": "",
        "outpayload1": "On",
        "outpayload2": "Off",
        "name": "Big Timer",
        "comment": "",
        "lat": "52.14",
        "lon": "4.44",
        "starttime": "5004",
        "endtime": "0",
        "starttime2": 0,
        "endtime2": "1410",
        "startoff": 0,
        "endoff": "15",
        "startoff2": 0,
        "endoff2": 0,
        "offs": "+2",
        "outtext1": "",
        "outtext2": "",
        "timeout": 1440,
        "sun": true,
        "mon": true,
        "tue": true,
        "wed": true,
        "thu": true,
        "fri": true,
        "sat": true,
        "jan": true,
        "feb": true,
        "mar": true,
        "apr": true,
        "may": true,
        "jun": true,
        "jul": true,
        "aug": true,
        "sep": true,
        "oct": true,
        "nov": true,
        "dec": true,
        "day1": 0,
        "month1": 0,
        "day2": 0,
        "month2": 0,
        "day3": 0,
        "month3": 0,
        "day4": 0,
        "month4": 0,
        "day5": 0,
        "month5": 0,
        "day6": 0,
        "month6": 0,
        "day7": 0,
        "month7": 0,
        "day8": 0,
        "month8": 0,
        "day9": 0,
        "month9": 0,
        "day10": 0,
        "month10": 0,
        "day11": 0,
        "month11": 0,
        "day12": 0,
        "month12": 0,
        "d1": 0,
        "w1": 0,
        "d2": 0,
        "w2": 0,
        "d3": 0,
        "w3": 0,
        "d4": 0,
        "w4": 0,
        "d5": 0,
        "w5": 0,
        "d6": 0,
        "w6": 0,
        "xday1": 0,
        "xmonth1": 0,
        "xday2": 0,
        "xmonth2": 0,
        "xday3": 0,
        "xmonth3": 0,
        "xday4": 0,
        "xmonth4": 0,
        "xday5": 0,
        "xmonth5": 0,
        "xday6": 0,
        "xmonth6": 0,
        "xday7": 0,
        "xmonth7": 0,
        "xday8": 0,
        "xmonth8": 0,
        "xday9": 0,
        "xmonth9": 0,
        "xday10": 0,
        "xmonth10": 0,
        "xday11": 0,
        "xmonth11": 0,
        "xday12": 0,
        "xmonth12": 0,
        "xd1": 0,
        "xw1": 0,
        "xd2": 0,
        "xw2": 0,
        "xd3": 0,
        "xw3": 0,
        "xd4": 0,
        "xw4": 0,
        "xd5": 0,
        "xw5": 0,
        "xd6": 0,
        "xw6": 0,
        "suspend": false,
        "random": false,
        "randon1": false,
        "randoff1": true,
        "randon2": false,
        "randoff2": false,
        "repeat": false,
        "atstart": true,
        "odd": false,
        "even": false,
        "x": 920,
        "y": 300,
        "wires": [
                "d93fde85253c3fc8"
        "id": "d77ff7ed88cbcc10",
        "type": "inject",
        "name": "Initialize",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 140,
        "y": 40,
        "wires": [
                "04575b33627ee32b"
        "id": "04575b33627ee32b",
        "type": "register-device",
        "name": "Night Light Trigger",
        "device_id": "06251b43-eacc-43da-9d1e-60d67e24d79d",
        "device_name": "Night Light Trigger",
        "capabilities": "{\"toggleNum\":\"1\",\"values\":[\"power\"]}",
        "manufacturer": "NodeRed",
        "model": "C1",
        "firmware_version": "1.0.0",
        "service_address": "192.168.86.32",
        "tags": "{}",
        "state": "{}",
        "x": 370,
        "y": 40,
        "wires": [
        "id": "d93fde85253c3fc8",
        "type": "switch",
        "name": "",
        "property": "payload",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "On",
                "vt": "str"
                "t": "eq",
                "v": "Off",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 1110,
        "y": 300,
        "wires": [
                "b7f61ae1c4bbb023"
                "56e1a4fa7ccc6a0b"
        "id": "d999c41a6c613fbd",
        "name": "Paal3 Off",
        "list": "{\"type\":\"light\",\"deviceId\":\"a4c1383c459f7322\",\"light\":{\"power\":\"off\",\"brightness\":\"\",\"type\":\"color-temperature\",\"colorOrTemp\":\"\",\"hslStr\":\"\"}}",
        "device": "a4c1383c459f7322",
        "action": "",
        "x": 780,
        "y": 680,
        "wires": [
        "id": "a1cae70edfa44667",
        "name": "Paal2 Off",
        "list": "{\"type\":\"light\",\"deviceId\":\"a4c13881f81496ec\",\"light\":{\"power\":\"off\",\"brightness\":\"\",\"type\":\"color-temperature\",\"colorOrTemp\":\"\",\"hslStr\":\"\"}}",
        "device": "a4c13881f81496ec",
        "action": "",
        "x": 780,
        "y": 640,
        "wires": [
        "id": "56e1a4fa7ccc6a0b",
        "name": "NightLight trigger Off",
        "list": "{\"type\":\"single\",\"single\":\"off\",\"deviceId\":\"7945c1fe-7efd-4d71-9f03-eb6e873a2318\"}",
        "category": "switch",
        "device": "7945c1fe-7efd-4d71-9f03-eb6e873a2318",
        "action": "",
        "x": 1360,
        "y": 360,
        "wires": [
        "id": "aca98161d3633df9",
        "name": "Paal3 On",
        "list": "{\"type\":\"light\",\"deviceId\":\"a4c1383c459f7322\",\"light\":{\"power\":\"on\",\"brightness\":\"\",\"type\":\"color-temperature\",\"colorOrTemp\":\"\",\"hslStr\":\"\"}}",
        "action": "",
        "x": 780,
        "y": 560,
        "wires": [
        "id": "0fe7c531616fc6e5",
        "name": "Paal2 On",
        "list": "{\"type\":\"light\",\"deviceId\":\"a4c13881f81496ec\",\"light\":{\"power\":\"on\",\"brightness\":\"\",\"type\":\"color-temperature\",\"colorOrTemp\":\"\",\"hslStr\":\"\"}}",
        "action": "",
        "x": 780,
        "y": 520,
        "wires": [
        "id": "b7f61ae1c4bbb023",
        "name": "Night Light trigger On",
        "list": "{\"type\":\"single\",\"single\":\"on\",\"deviceId\":\"7945c1fe-7efd-4d71-9f03-eb6e873a2318\"}",
        "action": "",
        "x": 1360,
        "y": 240,
        "wires": [
        "id": "d382ac56b6cc7edb",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 140,
        "y": 80,
        "wires": [
                "dd83c84da5361f96"
        "id": "dd83c84da5361f96",
        "name": "Night Light Enabled",
        "device_id": "dd112f56-06f0-4caf-919f-1a392db8605c",
        "device_name": "Night Light Enabled",
        "model": "C2",
        "tags": "{}",
        "state": "{}",
        "x": 370,
        "y": 80,
        "wires": [
        "id": "78e61e394cf2644e",
        "type": "event-state",
        "name": "status change night light enabler",
        "list": "",
        "device": "6eedcd9a-1e64-405d-b11f-38852f953ddc",
        "state": "all",
        "x": 170,
        "y": 300,
        "wires": [
                "2c34a1b426902321"
        "id": "30b1ac16eb0b58d8",
        "type": "switch",
        "name": "State",
        "property": "payload.payload.power.powerState",
        "rules": [
                "t": "eq",
                "v": "on",
                "vt": "str"
                "t": "else"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 590,
        "y": 300,
        "wires": [
                "8d0678178dba67a6"
                "b7063233aab1f0e1"
        "id": "2c34a1b426902321",
        "type": "json",
        "name": "",
        "action": "",
        "pretty": false,
        "x": 430,
        "y": 300,
        "wires": [
                "30b1ac16eb0b58d8"
        "id": "8d0678178dba67a6",
        "type": "change",
        "name": "auto",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "auto",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 750,
        "y": 280,
        "wires": [
                "9c02cfa3137da37a"
        "id": "b7063233aab1f0e1",
        "type": "change",
        "name": "stop",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "stop",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 750,
        "y": 340,
        "wires": [
                "9c02cfa3137da37a"
        "id": "b8d8efe567110ee5",
        "type": "inject",
        "name": "On",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 1110,
        "y": 240,
        "wires": [
                "b7f61ae1c4bbb023"
        "id": "b97a19b02cb9f66f",
        "type": "inject",
        "name": "Off",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 1110,
        "y": 360,
        "wires": [
                "56e1a4fa7ccc6a0b"
        "id": "9895f86ff71ea018",
        "name": "Paallamp",
        "device_id": "38b8f85e-a0ef-44a5-8fa1-95b07473d289",
        "device_name": "Paallamp",
        "capabilities": "{\"toggleNum\":\"1\",\"values\":[\"power\",\"brightness\"]}",
        "manufacturer": "Node-Red",
        "model": "C3",
        "tags": "{}",
        "state": "{}",
        "x": 340,
        "y": 520,
        "wires": [
        "id": "19fb435f458ffa16",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 140,
        "y": 520,
        "wires": [
                "9895f86ff71ea018"
        "id": "bc5a3f515e77a523",
        "name": "Status event paallamp",
        "list": "",
        "state": "all",
        "x": 160,
        "y": 580,
        "wires": [
                "738c6979b5619919",
                "8b15fa9e6ea94287"
        "id": "1e3b029fe547c1f0",
        "type": "switch",
        "name": "State",
        "rules": [
                "t": "eq",
                "v": "on",
                "vt": "str"
                "t": "eq",
                "v": "off",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 590,
        "y": 580,
        "wires": [
                "aca98161d3633df9",
                "0fe7c531616fc6e5",
                "757dcff6124d9b7e"
                "d999c41a6c613fbd",
                "a1cae70edfa44667",
                "62046c93492c9f8d"
        "id": "738c6979b5619919",
        "type": "json",
        "name": "",
        "action": "",
        "pretty": false,
        "x": 430,
        "y": 580,
        "wires": [
                "1e3b029fe547c1f0"
        "id": "757dcff6124d9b7e",
        "name": "Paal1 On",
        "list": "{\"type\":\"light\",\"deviceId\":\"a4c13872eb928cdd\",\"light\":{\"power\":\"on\",\"brightness\":\"\",\"type\":\"color-temperature\",\"colorOrTemp\":\"\",\"hslStr\":\"\"}}",
        "device": "a4c13872eb928cdd",
        "action": "",
        "x": 780,
        "y": 480,
        "wires": [
        "id": "62046c93492c9f8d",
        "name": "Paal1 Off",
        "list": "{\"type\":\"light\",\"deviceId\":\"a4c13872eb928cdd\",\"light\":{\"power\":\"off\",\"brightness\":\"\",\"type\":\"color-temperature\",\"colorOrTemp\":\"\",\"hslStr\":\"\"}}",
        "action": "",
        "x": 780,
        "y": 600,
        "wires": [
        "id": "1efaacefa1fb36b7",
        "name": "Paallamp On",
        "list": "{\"type\":\"light\",\"deviceId\":\"984db14d-dd32-47f1-8fe5-ce022f90f545\",\"light\":{\"power\":\"on\",\"brightness\":\"\",\"type\":\"color-temperature\",\"colorOrTemp\":\"\",\"hslStr\":\"\"}}",
        "action": "",
        "x": 810,
        "y": 940,
        "wires": [
        "id": "b0c151337ced450c",
        "name": "State event night trigger",
        "list": "",
        "state": "all",
        "x": 180,
        "y": 980,
        "wires": [
                "b4feb39e63bfa81d"
        "id": "b4feb39e63bfa81d",
        "type": "json",
        "name": "",
        "action": "",
        "pretty": false,
        "x": 450,
        "y": 980,
        "wires": [
                "dc876222717dd301"
        "id": "dc876222717dd301",
        "type": "switch",
        "name": "State",
        "rules": [
                "t": "eq",
                "v": "on",
                "vt": "str"
                "t": "eq",
                "v": "off",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 610,
        "y": 980,
        "wires": [
                "1efaacefa1fb36b7"
                "682221649ae351c2"
        "id": "fab388f7835f3922",
        "type": "debug",
        "name": "debug 2",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 980,
        "y": 660,
        "wires": []
        "id": "de61d84fb3c8d6bf",
        "name": "",
        "list": "",
        "state": "brightness",
        "x": 940,
        "y": 540,
        "wires": [
                "fab388f7835f3922"
        "id": "9574accdb28de1dd",
        "type": "debug",
        "name": "debug 3",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 940,
        "y": 840,
        "wires": []
        "id": "2e2f493a8804f601",
        "type": "debug",
        "name": "debug 4",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 160,
        "y": 900,
        "wires": []
        "id": "8b15fa9e6ea94287",
        "type": "change",
        "name": "change serial naar Paal1",
        "rules": [
                "t": "change",
                "p": "payload",
                "pt": "msg",
                "from": "984db14d-dd32-47f1-8fe5-ce022f90f545\",\"third_serial_number\":\"38b8f85e-a0ef-44a5-8fa1-95b07473d289",
                "fromt": "str",
                "to": "a4c13872eb928cdd",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 210,
        "y": 780,
        "wires": [
                "b982488ed0ef73aa"
        "id": "6b7d215fe10834e4",
        "name": "paal 1",
        "action": "",
        "x": 950,
        "y": 760,
        "wires": [
        "id": "b982488ed0ef73aa",
        "type": "json",
        "name": "",
        "action": "",
        "pretty": false,
        "x": 430,
        "y": 780,
        "wires": [
                "34f68e9e4218ada7"
        "id": "34f68e9e4218ada7",
        "type": "switch",
        "name": "brightness between 0 and 100",
        "property": "payload.payload.brightness.brightness",
        "rules": [
                "t": "btwn",
                "v": "0",
                "vt": "num",
                "v2": "100",
                "v2t": "num"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 670,
        "y": 780,
        "wires": [
                "6b7d215fe10834e4",
                "9574accdb28de1dd"
        "id": "47b82da33cd7c32b",
        "type": "api-server",
        "name": "iHost",
        "ip": "ihost.local",
        "ipaddr": "192.168.1.10",
        "token": "e3ebbcda-5aa7-4057-a7d2-7f67a6c56d4e"
Regards Rick
@hiconkong @Jemma hey do you mind taking a look?
Can anybody look at this?
Regards Rick
hey
I just got feedback from dev, and more info is needed. So could you please download the Node-Red log right after you control the device?
You can attach it here or Google Drive.
Thx in advance
