Is it possible to control the NspanetPro thermostat on a mac (or PC)?
Impossible to find a way to control the Nspanel Thermostat on a web page
  • I tried on ewe link web
  • I tried on home assistant
  • I tried on the web interface to Nspanel (what the use of this page ???)
-> In all environments, even just switching from automatic to disable seems impossible !
So am stuck on my phone ??? it seems incredible …
Is this right ? Is there a plan for using the nspanel remotely on at least one of the available interface ???
It looks like there isn’t one…
The only thing that comes to mind is to create custom scenes using webhooks and use those for control.
Or, try testing:
However, I suspect that this might not have been updated in such a long time that devices like the NSPanel Pro didn’t even exist back then.
I really don’t understand how sonoff treat his line of products
They have really good products but sometime when you use them, you realise that they stay at the level of gadget even if they have potentials
Hi, if you’re using the Central Thermostat type (designed for home heating systems), it can currently be configured and controlled through the local web interface.
If you’re using an individual Room Thermostat, there is currently no way to control it through the web interface.
Thank you for your feedback. I’ll pass this on to our team and include it in our next-stage planning.
And finally, I’m sorry that we didn’t consider this use case thoroughly enough, which has caused this inconvenience.
Thanks for your reply.
I would like to use central thermostat, but you don’t seem to take in account the wifi actuators. It is restricted to zigbee .. So ..It can’t work !
And impossible to use 2 actuators (if you have 2 electric heater !) at the same time
(ok i can create scenes where one actuator is synchronised with the only actuator linked to the thermostat …)
This is worse then what I could imagine
In reality, the room thermostat doesn’t work at all
  • I ask for a regulation at 20°c with an accuracy of 0,3 and the heater continues to work at 21
  • AND it is the Third time that i redo the schedule as it is lost and every period is reset to the whole day so in fact all the schedule is erased every time
i will try to do something in home assistant because obviously programation in ewelink isn’t working
but now i am in a deep … As the flat where are the heaters is hundreds of km from where I am … !!!
The Central Thermostat does support Wi-Fi devices. However, since the Central Thermostat runs locally on NSPanel Pro, you first need to add the device to the NSPanel Pro split-screen, and then select it in the Central Thermostat settings.
Do you mean that the thermostat created in the eWeLink App > NSPanel Pro > Thermostat section is not working as expected?
If so, once the issue occurs, please submit both the NSPanel Pro logs and the eWeLink App logs as soon as possible so we can investigate further.
For the eWeLink App:
App > Profile > Help & Feedback > Feedback > Submit Feedback
Glad to hear that it is possible to add a wifi actuator This was not obvious !
So i added it to a panel … Ok
Went to the central heating page (on the nspannelpro … as it seems to be the only way to settle it !! ) ->Add
Then fill all the fields for a room an a second one
And … Press “enregistrer” (it should be record or validate or ..Whatever in english)
And everything was lost.
Tried two three four time .. The informations are not recorded
So i come back to the room thermostat
Where every time you modify something the schedule is destroyed !
This is really unpleasant
i just sent the logs (2026-11-12 09:34:47 - device : 100251d296)
Hi, could you please record a short video showing the exact steps where the issue occurs?
This will help us understand the problem more clearly, locate the cause more quickly, and make the necessary improvements.
It’s too late, this panel is in a house at 200 km from where i leave and i just came back yesterday
I just noticed that it can be done remotely …
But the result is the same when i press save … Answer : FAILED
by the way, there were an upgrade to ns panel yesterday why doesn’t it appear on the firmware update page on ewe link web ? concentrating information should be easier for user
Ps) i have 5 nspanelpro .. Could you please indicate the name of the one you see on the front page of their web interface ?
Let’s go through your issues one by one:
Regarding the thermostat configuration issue, I’m sorry, but I may not have fully understood the problem. Could you please record a short video showing the exact steps and what happens? That would help us understand it more clearly.
As for the local web page not being able to receive the new version update, I’ll check this with the relevant team and confirm the situation.
Do you mean how to access the local web interfaces of different NSPanel Pro devices when you have multiple units?
You can find the access address on the NSPanel Pro screen under Settings > Local Web Portal.
There are two ways to access it:
  1. Access directly using the device IP address
  2. Access using the local hostname:
    http://nspanelpro-deviceid.local
Each NSPanel Pro has its own device ID, so you can use the corresponding address to access each device separately.
1st point … I am kilometres away and don’t have physical access to this panel. What can i do remotely ? (i have the same problem on the central heating port of the NsPannel PRO page, where saving is also impossible)
2 ) no, what i mean is : you have on ewelink web a page for upgrading the firmware of all your devices .. But not the ns panel .. you should concentrate !
  1. i can access the web pages of the ns panels without problem ! The thing is when you open a page you see the title “NsPannel PRO” .. But not he name of THE NsPannel you are on .. (you have to go to the setting page to know where you are)
I realized that I had mixed up eWeLink Web with the NSPanel Pro Local Web Portal.
  1. Regarding the issue where the text cannot be saved, I’m not completely sure which page or exact steps you are referring to. If the issue still exists and it’s convenient for you, could you please record a short video showing the process? Thank you in advance for your time and patience.
  2. We will record your feedback about whether eWeLink Web can support NSPanel Pro OTA updates and pass it on to the relevant team. I’ll keep you updated if there is any progress.
  3. I understand your point now. You mean the top-left corner of the Local Web Portal should display the device name, instead of showing the same “NSPanel Pro” label for every device. I’ll plan to have this improved in one of the upcoming versions.
Just pressed save with this setting just for one room
Answer : FAILED
(attachments)
