Improvements requested
after yeras or use, improvements can be:
  • Solve DST time
  • Sunrise /sunset Offset bigger (1 hour)
  • Scene turned off itself (forr avoiding repeating same escene) For example, If I want a movement sensor turn on a device, when done, thre is no need to do it again an again every time movement sensor is triggered.
  • Scene triggered by two DIFFERENT SENSORS in THE SAME RF BRIDGE
About the third bullet: You can enable/disable scenes from other scenes. Maybe that helps.
I know but It is better auto disable scene when finishing
Enviado desde Outlook para Android
