iHost custom Repository
Hey
You need to input the path to the image after you set up a third-party repo
I just tried your link and managed to pull it.
Use this for
ghcr.io/t0bst4r/home-assistant-matter-hub:3.0.0-alpha.49
does matter hub docker work? What are the startup settings?
Are you referring to the Python Matter Server for HA? It’s not meant to be used outside HAOS or HA Supervised setup.
In your screenshot, you added the Matter hub to Docker. How do I launch it? What are the settings? This project (home-assistant-matter-hub) has the ability to run in docker and specify the path to the home assistant server. I have a home assistant in docker, but I do not know how to properly run this project in docker.
Hey,
I was just demonstrating how the third-party docker repo works using the one that other users mentioned in this thread. It’s not a specific guide on how to use HA Matter Server. That project is just a backend of HA Matter feature.
If you want to add Matter devices to iHost, please go to + —— Add Device ——Add Matter Devices
how to install specific version of package?
i need to FileBrowser 2.30.0
Install specific image version is not supoorted for now.
Is it possible to run this container on iHost?
I added it like this, repository URL:
And in this repository, I added it like this:
ghcr.io/ihost-open-source-project/armv7-addon-matter-server:8.1.1@sha256:515fd1306609a8107b28b80eef4a3280e8b5cbc74c8f8ac6a0fd518d9461dca2
But I don’t know what parameters to run it with…
