Today I’ve found a bug using the ihost smart scenes.
Using a TH16R2 device temperature or humidity settings.
In ihost web interface appears only the value equal or lower. The equal or higher is missing.
For now a smart device can be selected once in a scene, you can create 2 Scenes to meet your needs.
Scene 1 If x ≤Temp
Scene 2 If Temp ≤ y
the left blank is for the equal or higher. please double-check.
Please double check
Value1 ≤ Temp ≤ blank
Means temperature greater than the Value1 you set.
blank ≤ Temp ≤ Value2
Means temperature less than the Value2 you set.
