Hi
I’ve upgraded on of my Pro120 and this is all I get, I can’t see to do anything else. A reboot just takes me back to this.
any ideas what it says and also how to recover
If your NSPanel Pro boots into a screen that says Factory Mode and refuses to activate, here is what the message means and how to fix it.
What the Chinese text on the screen means (English translation):
This screen normally appears only in the factory during production testing.
If you see it at home, the device did not complete its activation or is running a factory/test firmware.
Why NSPanel Pro enters Factory Mode?
This is a software state, not a hardware failure.
How to Exit Factory Mode / Recover NSPanel Pro?
Try “Activate Device” (simple fix)
If the panel has Wi‑Fi access:
Full reboot
Enter Recovery Mode (official method)
NSPanel Pro has a built‑in recovery loader.
Method A
This works on most firmware versions.
Method B
USB‑C bootloader mode (advanced). Useful if the device is bricked.
Flashing Official Firmware. You can restore the system in two ways.
Method A
OTA firmware via eWeLink (recommended)
If the device appears in eWeLink:
Method B
Manual firmware flash (USB‑C)
For devices stuck in Factory Mode or with corrupted firmware.
You need:
Commands:
bash
fastboot flash system system.img
fastboot flash boot boot.img
fastboot flash vendor vendor.img
fastboot reboot
After reboot, the device should start normally.
Summary
If your NSPanel Pro shows Factory Mode, it simply means:
Something from these suggestions should work, but I can’t guarantee it. Diagnosing this remotely is difficult. Similar cases have already been discussed on this forum, and the eWeLink team usually helps out. They seem willing to assist now as well. Just wait a bit — they will probably respond.
Thanks. Am away at present so will try when back home.
