How to avoid false activations with your finger when browsing ewelik
While navigating the app, switches are often activated unintentionally, such as a main gate. Is there an option in the app to prevent this? There should be an option for each switch asking if you're sure you want to activate it... Or perhaps the side activation button should be removed, so that if you want, you can access the switch itself and the button will appear there
When scrolling up or down the menu, the right side button is often activated. These should be on the left, or there shouldn’t be any buttons at all.
I’ve also requested a similar function a few months ago. Apparently there are quite a number of people requesting this, so I guess it’s on a backburner somewhere.
It seems super easy to implement, perhaps they’ll make it available in a higher subscription tier LOL
