I just moved my smart devices to home Assistant and having an issue with 1 particular automation.
this worked when i used it on Ewelink app. when sonoff humidity (set %) is high, wifi mini relay switches fan on. i also have another scene to tuen it off when humidity meets reduced %.
i have created the same automation in home assistant integration and it does not activates. what am i doing wrong please
This is automation config, not a log.
Go through the log and check why is it failing. Also, you can always run any automation manually to check if there are any errors. If it fails, you should be able to find the cause easily.
homeassistant.components.homeassistant.triggers.numeric_state
Source: components/homeassistant/triggers/numeric_state.py:185
Integration: Home Assistant Core Integration (documentation, issues)
First occurred: 10:13:17 AM (2 occurrences)
Last logged: 10:26:30 AM
Error in ‘Low Humidity’ trigger: In ‘numeric_state’ condition: entity sensor.lumi_lumi_weather_humidity_3 state ‘’ cannot be processed as a number
It could be that you are using a wrong entity here, where the value is not a number. You should check all your entities, including the one already in use.
