Adding battery value to the smart scene option
gents,
i have humidity and temperature sensor. can you please add the battery value to the condition so that if the battery is low i need to do an action.
Thank you for your post! Could you please provide a screenshot of the current status and display of the sensor?
Thank you for your reply
The sensor is sonoff SNZB-02D
When you create a scene you select the sensor the only options you can set is temperature or humidity for condition.
The template for the sensor can display the battery, temperature and humidity
Since you can read it as a value then why you do not add it to the condition.
I will confirm the scheduling of this feature with the product team and get back to you soon.
Thank you for your patience! Regarding the battery reminder feature, we will add a low battery alert function in the next version, and the system will push relevant notifications. However, if you need it to be used as a trigger condition for automation in Scenes, it may be scheduled for after August.
