Google Home devices with DUALR3
Hi!
I have my account linked with Google Home, and I have some problems with the DUALR3:
1- I have the DUALR3 set as “separate devices” in the app, to be able to select each output individually. Then in google home I see the DUALR3 device, and each of the lights again. So if I have a light on in the kitchen, it says that I have “2 lights on” (the DUALR3 and the separated one).
2- In the same setting as before I also see a DUALR3-curtain as a disconnected device. Maybe this is because I configured this device as a curtain once to test the functionality, but now it is present in google home all the time
3- If I configure the DUALR3 as a curtain, I’m not able to control it, it appears as a ON/OFF device (with a “Play” triangular symbol). I’m planning to update all my blinds in short, so any solution would be appreciated
Don’t know if anybody has experienced any of this and has any solution. Thank you for your help
Alex
