Just be careful as there is a wifi version and if you look at buying one it is easy to accidentally buy that one. There is also not a separate W channel and it’s only RGB. The iHost thinks it is an RGB bulb. No experience with RGBW strips. I would check the specs on the newer bulbs from Sonoff as I’d expect a working device to pretend to be a bulb. If they don’t have a white channel I’d be more careful.
