Fingerbot/ eWelink
Hi All, is there a fingerbot thats working with aWelink ?
Greetings, Pieter
NO yet, i think SONOFF is making plans for that.
@Daniel_Zhan how do you think?
Hi has there been any updates on this? Does Fingerbot work with ewelink through Zigbee bridge?
hi
some news about the fingerbot ???
cheers
Not yet?
No luck yet. Have a ZigBee fingerbot and it just shows has a switch, but does nothing
My Moes Zigbee Fingerbot Plus would switch briefly on and then turn off when connected to an iHost but could not change. You could not change it so it switched from on to off so I moved it to Zigbee2MQTT.
Hello!
Anyone know if there are news about that?
I’m also looking for a fingerbot compatible with iHost. Any suggestions? Thanks!
I recommend it to anyone who has a version of this device.
Pair it with iHost and generate and save all the logs generated by it.
Check if it is compatible with Z2M and send the information here with the product link in Z2M so that the Devs can see if it would be possible to add them to the compatibility.
I have this fingerbot conected to iHost:
Tuya Zigbee Bluetooth Fingerbot Plus Robot Button Pusher Switch Bot Smart Home Work With Alexa Google Home Smart Life App - AliExpress 44
It work but I have some problems, which I was described here:
Fingerbot on iHost - eWeLink CUBE - eWeLink Forum
