eWeLink Web V3.13 Update on March 06 -- Check your Home sharing & Device sharing
要求有旧版界面那种直接按钮。
旧版界面可以直接开关,现在的二级菜单开关太不方便了。
Hi Morgan, regarding the issue of device status not updating in time when using the CAST website in the Fennec F-Droid browser, we have not tested using CAST in that browser before. We will try it out and see if we can reproduce the issue.
As for the other issue with the CAST app showing a white screen on Android 8.1 Go, were you logging into the CAST app on your phone?
Thx
I just checked again, logged out completely from ewelink app and web.
After deleting the data/cache from the CAST app, the app started again and allowed me to select the cast cloud and log in to my account. Then the white screen again and the available panel on the left side and nothing else.
After turning off the app and turning it back on, it hangs on the welcome screen.
I run the CAST app on a 10-inch tablet with Android 8.1 Go and 1GB RAM, of which about 600MB is free.
On a phone with Android 7.1, the CAST app is listed as incompatible in the Play Store, but when I download the apk and install it, the app tries to initialize but it just looks like the screen blinks and nothing else, the app doesn’t start, so I speculate that the CAST app is actually not compatible with phone and only works on tablet. :slight_smile:
Hi Morgan, yes the CAST app is designed to be used on tablet devices, so you may encounter issues when attempting to use it on a phone.
Since phones have smaller screens optimized for touch interfaces, the CAST app’s interface and functionality may not display or work properly. This could explain the blank white screen you are seeing.
Our recommendation would be to use CAST on a tablet as intended for the best experience.
The problem with CAST app behavior occurs on a 10-inch Tablet. :slight_smile:
  1. Tryb ciemny
  2. Archiwum przechowywanych danych.
    W historii mogę cofnąć się tylko na 3 miesiące wstecz (kWh) urządzenie PSF-X67 model TOB8-63WIFI marka TOMZN. Jest to jak dla mnie główny element blokujący poszerzenia wykorzystywania urządzeń na tej platformie IOT. Konkurencyjna Tuya nie ma żadnych ograniczeń co do czasu przechowywanych danych odnośnie gromadzonych parametrów. Trzy miesiące to zdecydowanie mało, bardzo mało.
It would be best if you were able to write in English.
It would be better to let a user possibility to lock a separate device for accidentally switching
hello - Provide stats on how long the device that is using the smart plugs is using power. You have it so it just how long the plug is in the on position not how long the plug has register power from the device it is plugged into. For example a heater is plugged into it but because the heater cycles on and off I like to know how many hrs it was using power, not how many hrs the plug was on. :slight_smile:
Hi Morgan, I thought you were referring to having the problem on a phone, do you also have this problem using the CAST App on a 10-inch tablet with Android 8.1 Go and 1GB RAM?
The problem has been with the tablet from the beginning. CAST app, as I described earlier, does not want to work properly.
When I run the application for the first time, I reach the stage of selecting the local/cloud mode and adding/logging in to the account. Later only a white screen.
The second and each subsequent launch of CAST app, the application hangs on the start/welcome screen and stays like this forever.
Tablet 10inch, Android 8.1 Go, 1GB ram.
May I know the version of the eWeLink CAST App you installed?
1.2.0
Thank you, Morgan, could you please send your eWeLink account through a private message? Click on my avatar and you will see a message button.
Please make the “Effective Period” control work in Scenes. Would be very useful, if only it worked. Thank you.
Please add thermostats control. I have 9 different thermostats implemented and it would be convenient to control them from a single place on a large screen.
Please can we have more Webhook functions. For example, adjust inching time for SmartSwitch / adjust brightness / colour for Smart Light Bulb.
I understand that these variables are not available in “Then” / smart device?
Correct. These variables are not available in “If” or “Then”.
Get BlueMail for Android
