eWeLink CUBE OS Docker Installation Support is Here!
Hello Community!
In the latest version CUBE OS 2.10.3, you can now run CUBE as a Docker container! This opens up new possibilities for deploying CUBE on NAS devices, home servers, and other Linux machines.
Currently Supported Architectures
CUBE Docker currently supports the following architectures under Linux systems only:
  • amd64 (x86_64) — regular PCs, servers, Synology NAS, QNAP NAS, etc.
  • arm64 (aarch64) — Raspberry Pi 4/5, Orange Pi, Apple Silicon Mac (via Linux VM), etc.
Note: Docker images are built for Linux containers. If you’re on Windows or macOS, we highly recommend using the one-click installer. Please check One-click Installation | eWeLink CUBE.
Before You Start
Make sure port 80 and port 1883 are not in use on your host machine:
  • Port 80 — CUBE Web UI (HTTP)
  • Port 1883 — MQTT (device communication)
If these ports are occupied (e.g., by nginx or Apache), you’ll need to stop those services first.
Quick Start
1. Pull the image
docker pull ghcr.io/ewelinkcube/cube-os:2.10.3
2. Start the container
docker run -d \
  --name cubeos \
  --privileged \
  --net=host \
  -v /xxx/data:/data \
  --device /dev/ttyUSB0:/dev/ttyUSB0 \
  -v /run/dbus/system_bus_socket:/host_dbus/system_bus_socket:ro \
  cubeos:2.10.3
Replace xxx with the actual directory path on your host where you want CUBE to store its data (e.g., /home/pi/cubeos-data).
Parameter Explained
Parameter Purpose
--privileged Privileged mode — CUBE needs access to host hardware
--net=host Host networking — required for device discovery and MQTT communication
-v /xxx/data:/data Mount data directory — replace xxx with your actual path; data persists across recreations
--device /dev/ttyUSB0 Pass through Zigbee dongle — only needed if you have Zigbee devices
-v .../system_bus_socket:ro Mount host D-Bus — required for eWeLink Remote and Matter Hub
3. Verify
docker ps
Then open your browser and visit http://your-device-ip
Important Notes
Due to Docker’s containerized architecture, some features are not available in the Docker version:
  • Add-ons — cannot install/manage add-ons (like Node-RED, Z2M, etc.)
  • Bluetooth Speaker — Bluetooth hardware passthrough is not supported
  • System Update — cannot update CUBE from the web UI (you need to pull the new image and recreate the container)
  • Reboot / Shutdown — these system-level controls are not available
How to Update CUBE OS
Since the Docker version doesn’t support OTA updates, you’ll need to update manually when a new version is released. Don’t worry — your data is safe as long as you’ve mounted the data volume.
# 1. Stop the old container
docker stop cubeos
# 2. Pull the new image (replace X.X.X with the new version)
docker pull ghcr.io/ewelinkcube/cube-os:X.X.X
# 3. Start a new container with the same parameters
docker run -d \
  --name cubeos \
  --privileged \
  --net=host \
  cubeos:X.X.X
Note: Use the same startup parameters as before. Replace xxx with your actual data directory path and X.X.X with the new version number. Your config, devices, and scenes are stored in the mounted data directory, so they will persist across updates.
Raspberry Pi Users
If you’re using a Raspberry Pi, make sure your page size is set to 4K:
# Check current page size
getconf PAGE_SIZE
# If it's not 4096, add this line:
echo "kernel=kernel8.img" | sudo tee -a /boot/firmware/config.txt
sudo reboot
Want Support for More Architectures?
We currently support amd64 and arm64 Linux systems. If you’d like us to support other architectures (like arm32, etc.), please leave a comment below and let us know what hardware you’re using!
My docker-compose files usually have memory and CPU limits for each docker container. What settings would you recommend?
For example I have Jellyfin set to 2GB and 2.0 CPU.
I was thinking of getting a RISC V device to play with. Maybe that architecture would be useful. My guess is it’ll be more popular in future. Not sure much has 32bit ARM anymore.
Raspberry Pi 4 and 5.
We recommend using the 2C2G configuration for the Docker version, which should be sufficient for everyday iHost operations. If you find that memory usage is high during later use, you can flexibly increase the allocated memory as needed.
how about docker compose ?
Hello, are you requesting that we provide an example docker-compose.yml file?
Which formats does your docker work on ARM64, X86 and RISC V?
Hello, currently the Docker images for eWeLink CUBE OS support two architectures: amd64 (x86_64) and arm64 (aarch64). They can run on standard PCs, servers, Raspberry Pi 4/5, and other compatible devices.
yes if possible , also to mention requirements if running at proxmox
Hello, and thank you for the support regarding CubeOs in Docker containers.
I encountered the following error in the Docker implementation when using the “Create Backup” function(CubeOs2.12.0):
Failed to create backup “”: Error: ENOENT: no such file or directory, open '/data/.dockerd/image/overlay2/repositories.json
I created the missing file using the following command, and the backup is now working.
echo ‘{“Repositories”:{}}’ > /data/.dockerd/image/overlay2/repositories.json
Please check whether this error was specific to my installation or if it is a general issue with the Docker implementation.
Many thanks in advance,
Martin
I am using Docker on:
DEBIAN_VERSION_FULL=13.6
Server: Docker Engine - Community
Engine:
Version: 29.6.2
API version: 1.55 (minimum version 1.40)
Go version: go1.26.5
Git commit: 3d80467
Built: Thu Jul 16 16:13:12 2026
OS/Arch: linux/arm64
Experimental: false
containerd:
Version: v2.2.6
GitCommit: 11ce9d5f3c68c941867e82890e93e815c1304f1b
runc:
Version: 1.3.6
GitCommit: v1.3.6-0-g491b69ba
docker-init:
Version: 0.19.0
GitCommit: de40ad0
Log File
./data/.logs/aibridge-recovery/aibridge_recovery.log
[2026-07-26T09:42:20.616Z] [INFO] default - [OperationManager] - Operation 11 is at stage addon, 25.761570727811023% completed.
[2026-07-26T09:42:20.619Z] [INFO] default - [BackupManager] - ReleaseVersion ignore mountSDCard…
[2026-07-26T09:42:20.622Z] [ERROR] default - [BackupManager] - Failed to create backup br8p4ytjnb_1785058936995: Error: ENOENT: no such file or directory, open ‘/data/.dockerd/image/overlay2/repositories.json’
at async open (node:internal/fs/promises:633:25)
at async Object.readFile (node:internal/fs/promises:1237:14)
at async BackupManager.getAddonImageCount (/root/aibridge-recovery/src/extension/backup_manager.js:1:29193)
at async BackupManager.createBackup (/root/aibridge-recovery/src/extension/backup_manager.js:1:15029) {
errno: -2,
code: ‘ENOENT’,
syscall: ‘open’,
path: ‘/data/.dockerd/image/overlay2/repositories.json’
[2026-07-26T09:42:20.625Z] [INFO] default - [BackupManager] - startAllServiceProcess start…
[2026-07-26T09:42:24.516Z] [INFO] default - [BackupManager] - startAllServiceProcess end…
[2026-07-26T09:42:24.516Z] [ERROR] default - [OperationManager] - Backup operation createBackup failed: ENOENT: no such file or directory, open ‘/data/.dockerd/image/overlay2/repositories.json’
[2026-07-26T09:42:24.526Z] [INFO] default - [OperationManager] - backup Operation 11 failed.
Thanks for confirming.
Below is an example compose.yaml based on the Docker command in the original post:
services:
  cubeos:
    image: ghcr.io/ewelinkcube/cube-os:2.12.0
    container_name: cubeos
    privileged: true
    network_mode: host
    restart: unless-stopped
    volumes:
      - ./data:/data
      - /run/dbus/system_bus_socket:/host_dbus/system_bus_socket:ro
    # Uncomment and adjust this path if a USB Zigbee coordinator is used.
    # devices:
    #   - /dev/ttyUSB0:/dev/ttyUSB0
Start CUBE OS with:
mkdir -p data
docker compose pull
docker compose up -d
Check the container status and logs with:
docker compose ps
docker compose logs -f cubeos
Please note:
  • Ports 80 and 1883 must be available on the host.
  • Uncomment and adjust the USB device path if a Zigbee coordinator is used.
  • We recommend approximately 2 CPU cores and 2 GB of available memory as a starting point.
Regarding Proxmox VE
I have not personally used or tested CUBE OS Docker in a Proxmox environment, so I do not want to provide detailed platform-specific instructions that have not been verified.
In general, the same Linux Docker requirements apply, including host networking, persistent storage, available ports, and USB passthrough if a Zigbee coordinator is used. If you need any technical guidance, we can investigate the specific requirements further.
Hello, thank you for your feedback. We apologize for any inconvenience this may have caused. We have identified the root cause of this issue, and it will be fixed in the 2.13.0 Docker version of Cube OS, which is scheduled for release in August.
Bug report: dynamic-security MQTT “Not authorized” on fresh Docker install (amd64)
Running CUBE OS 2.10.3 Docker image ( Package cube-os · GitHub ) on Ubuntu/Xubuntu, amd64, kernel 7.0.0, with --privileged and a macvlan network (container has its own LAN IP, ports 80/1883 reachable).
On a completely fresh install (empty data dir), the web UI loads but stays stuck on the red “Disconnected. Please check your Internet connection” banner, and the initial password setup / login does nothing.
Diagnosis from /data/.logs/aibridge-api/aibridge_api.log:
  • The regular MQTT client connects fine: “connect successfully” / “Connected to MQTT server” / subscribes and receives cube/supervisor/os/info.
  • But the [dynamic-security-mqtt] client repeatedly fails: [ERROR] [dynamic-security-mqtt] MQTT error: Connection refused: Not authorized.
/data/mosquitto/ contains only dynamic-security.json (generated, 1245 bytes), no separate mosquitto log. The error persists after docker restart, and also after a full wipe of the data dir + redeploy + restart — so it appears deterministic, not a first-boot race.
Network, DNS and core MQTT all work; only the dynamic-security admin client is rejected. Looks like a credential mismatch between the generated dynamic-security.json and the password the services use. Could you check the dynamic-security init on amd64 Docker?
Could you please follow the steps below to verify whether the issue can be resolved:
  1. Please check whether port 1883 is already in use on your host, or if any other MQTT broker is running. If so, please stop it first, as it may cause port conflicts.
  2. Delete all files in the host directory that is mounted to the container’s /data directory, or mount a completely new host directory instead.
  3. We also recommend that you use the latest version of the software, as older versions may be more difficult to troubleshoot.
