eWeLink API for JavaScript
We use eWeLink API for JavaScript published on Github. It appears that the delay or latency between sending a message and the response by the device (mainly Sonoff) is variable by up to ten minutes. Is this to be expected or is it more likely to be an error in out JavaScript code
It’s likely there is an issue in the code. You can refer to it: https://www.npmjs.com/package/ewelink-api-next.
Thanks - will try in next release of our product.
