Evelink cast grafica
Buongiorno dall’italia, sono contentissimo di questo prodotto e grazie agli svilupppatori.
Vorrei chiedere di inserire il colore rosso in caso di sensore di porta aperta, in maniera tale che sulla dashboard sia ben evidenziato.
Grazie
Thx for the feedback!
Are u suggesting using red for status like motion detected/water leakage detected/door opened?
yes! beciuse in very easy to see the difference…for example green door is closed…red door is open…danger!
this is what it looks like in ihost cast
and this is the view in IHOST
in ihost, device states are poorly visible
You also need a log of currently executed scenes
Ottima la grafica rossa per gli accessi aperti…grazie
we need to somehow make visually distinguishable presence sensors and motion sensors. But in general, I personally expect at least some news about the development of a home map like Samsung.
The UI for WEB and CAST has been optimized for such devices, for instance:
Thank you, but that’s not what I’m talking about. The fact that you made all the sensors distinguishable from all other devices is just super. But the motion and presence sensors themselves are indistinguishable from each other, both there and there is a little man in a runner’s pose. And one more wish. All sensors, by default (when closed or when there is no movement, are displayed in the same color as other turned on devices). They need to be made a neutral color, the color of turned off devices.
grazie ottimo lavoro, sono d’accordo nello sviluppare sempre di piu il nostro cast!
vorrei chiedervi di poter personalizzare l’icona in cast della piastrella ingrandita. esempio: se ingrandisco la piastrella di una lampada, viene visualizzato un semplice interruttore on off. sarebbe molto bello avere la possibilità di personalizzare l’icona
grazie
Ciao…ci sono news sull’ingrandimento della pistella?
grazie
