DST coming again
Tonight DST again… I am not demanding advanced features: SIMPLY AUTOMATIC TIME ADPAPT to new time, as other IOT systems do.
Every DST everything gets crazy: Adjusting timers etc.
This madness has to finish
Agree. It’s totally nuts to think a smart device is so stupid…
Hi there. Please refer to the link below to adjust timers for DST.
Editing your timers back or forward simultaneously (coolkit.cn)
OK but If I have many scenes, and If I go to “STANDARD TIME TO DST” and apply to all scenes, tiem showed is NOT real time now.
THis is carzy. Every DST change I have to reordenate everything.
OTHER IOT ecosystems do this automaticaly, please you can not do this!!!
Is as simple a s put a DST ON/OFF!!!
IF I put an scene sarting al 21:45 scene has to start at 21:45!!!
I do not know why you do not change this
For example, sunset/sunrise works well after DST change. You konw what is my timezone and DST change
You can take my realtime from my phone.
I think your server write orders directly in my RF bridges. What is the problem???
You should know this ih the MAJOR PROBLEM you have with this IOT ssytem. That´s what I thin after some years of use
IOT is for doing things easier!!!
For the last 4 years 2x the same request and excuse over excuse. Not to fix it
But they have to know this is the biggest problem they have, until point I am thinking in changing IOT system, because my system now is very complex for these readjustmente every six months… Better flashing devices to other options… It,s a pity, but I will do that
Hello
It is the first modern application unable to integrate time changes. The current time is already in the phone, just go read it!
I only have one eWeLink device. It’s the first and it will be the last!
As long as this problem is not resolved.
I joined this forum to help developers, as I am ewelink user since some time… as IOT grows, with more devices, scenes etc. this stupid DST question gets very important because twice every years get my IOT crazy.
For people with one device and one scene could be the same, but wit a complex scene system DST implementation is a must
If I was in developing team, thsi will be THE FIRST question to solve, because this stupid question, for example, will cut market for this IOT system
For example, I am NOT going to use EWELINK in my mother house, because everything I do CHANGES TWO TIMES IN A YEAR, and THE FIRST I WANT when I create a Scene is STABILITY AT EVERYTIME
IF i want a device turns on at 8:00 AM everyday, is everyday at the same time
As said, I am looking on going to another IOT systems because I see the do not want to solve this, with arguments surrealistics
AAnothe problem is that I can change timers, but ¿what about periods? If I have a secene active in the 9:00 to 22:00 time period ¿How can I change this after a DST change?
Another argument for you to solve this as soon as possible
NOW I have timers running al 6:09 when the are programmed to run at 7:09 this is CRAZY
Timer have to run at programmed time. It is very easy
New DST and no progress on this stupid application.
Fortunately for me, I still only have one device.
Let’s wait until October when the developers wake up!
First time. No change off time. Amazing thanks :folded_hands: :folded_hands: :folded_hands: :folded_hands:
my iiHost seems to have the right time. Not got any built in scenes with time to know for sure but the temperature sensors are correct. Maybe it is just the app?
Fitst time DST worked OK. Thank you EWELINK
Totally agree
It’s better than it was, but here in UK, DST changed to GMT on Sunday 26th October.
I used the edit timers feature and logically used the DST to Standard time block change.
I have timers that start at 00:30 and end at 07:30 when in GMT then 01:30 to 08:30 in DST.
You would think that selecting DST to Standard would subtract an hour, but it doesn’t. It adds an hour to 02:30 to 09:30.
Do these people understand time changes?
Hi, I’ve been using sunrise and sunset automation for a year now.
Also timers.
I started right after the time change.
The spring updates were delivered before the time change.
There was no problem with the automation and everything went fine on Sunday, just like now.
At the beginning of the year I used the eWelink app and in the summer I used iHost.
Everything is fine.
The whole idea of DST is silly, luckily it’s not something we have to deal with in my country.
