Greetings! In hotel rooms’ balconies, I utilize mini R4m switches to illuminate facades. These switches are connected to push buttons, allowing guests to control the lights individually. Is there a method to temporarily disable push button control (s1/s2) for a specific duration? Thank you in advance.
I don’t think there’re any; correct me if anyone know
A workaround could be an automation when it detects states change, it would toggle the light back. Or use the inch feature.
What is the purpose of temporary disabling?
Physical switches cannot be disabled.
Disabling manual switches would enable me to keep all the lights on, especially during peak crowd times in the area.
That would work for me if I could give a duration to that fuction.
I would disconnect (detach relay) each Mini R4 S1/S2 from L(out)/N. Than I would create a smart scene for each Mini R4 that would reconnect each S1/S2 to L(out)/N via software adding its effective period.
Thank you for your answer. That would work for me. How could I achieve that? Would it be possible withing ewelink app?
No. You should use the app
