Between February 20 and 22, a firmware update (from 1.1.1 to 1.3.0) was performed on CK-BL602-SWP1-01(182) devices.
After the update, neither voltage, power consumption, nor current are measured. I use 15, many as threshold sensors.
I would like to continue using it, any ideas?
Have you updated the app to the latest version 5.13.1? It might solve your problem.
The update came this morning (5.13.1) and after that everything was fine again.
Thanks…
What do you mean you’re using them as threshold sensors?
Yes …
I would be happy if you could describe what you mean.
Hello
Since January 8th, the measurement of the CK-BL602-SWP1-01(182) (fw 1.3.1) in HA has stopped working again, only if the ewelink app is running on my phone. If I exit the app, the last measured data remains indefinitely. Again...
