Cast current consumption dashboard
In the cast screen, it would be great to see the current consumption for POWR320D devices or any device with a power meter feature.
For example, in my kitchen, I have two of these devices to monitor the consumption of the induction plate and other appliances. Unfortunately, I can’t see on the cast dashboard if I’m reaching the limit.
Additionally, I would like to create a dashboard to monitor the current consumption of my entire house, not just the kitchen.
Hi there, you can select the graph for the device when configuring the CAST dashboard.
Hi @StephenJ,
With this you cannot see how much it is consuming NOW, but how much it consumed from the past, I need a real time consumption, like the one that you can see in the eWelink app on your mobile.
Pasquale
If you press the POWR320D key, a new window opens.
The new window displays the current values.
I agree with colleague @ingpasquale.
It is necessary to be able to enlarge the key and display the current consumption information continuously. Without pressing the device tile
Hi, I have a POWCT and a S60TPF socket, I would also need to see the readings in real time. The buttons have been enlarged, but when I press them nothing appears
The screenshot of @ociepa.ekotox is from the iHost-Cast dashboard, which is developed by a different team—that’s why it looks different.
is this implementation planned?
Yes, I’ve forwarded the request to the internal team. They will see if it can be implemented in the upcoming versions.
