I’m developing a web app and looking for an example where Javascript/ and or PHP (or anything else) is used to trigger a eWeLink Webhook immediately and process its results. This code will be used to trigger a relay which in turn turns on and ESP32 microcontroller. Again, it is important that the relay is turned on immediately because it gates other functionality in my code.
Related topics
| Topic | Replies | Views | Activity | |
| Free discussion: How do you use eWeLink Webhooks on your DIY project? | 3 | 1389 | July 2, 2025 | |
| eWeLink Webhooks to combine eWeLink with other third-platform apps | 23 | 2016 | November 25, 2023 | |
| The eWeLink web not update realtime data until open the eWeLink app . and also when i call the eWeLink API | 0 | 268 | January 26, 2024 | |
| Control your eWeLink devices by using your PC keyboard via IFTTT Webhooks | 0 | 262 | September 15, 2021 | |
| In eWeLink Web V 3.0 Beta3, when creating a it was no longer possible to select the R5 switch and the EweLink 433 MHz hub as a trigger script | 0 | 132 | November 13, 2023 |
