Are there plans for the ZBridge Ultra to be able to run Cube OS?
Do you think it’s technically possible or not?
Technically speaking, CUBE OS and ZBBridge-U share many internal components. However, in terms of product form and definition, these two products are designed for different user scenarios.
I’m curious—which specific CUBE OS features would you like to see added to the ZBBridge-U?
Being able to create scenes from the local web portal that you just enabled would be faster than doing it from eWeLink.
Local scenes like in ewelink.
We’ll evaluate this feature internally. Thanks for the feedback.
Additionally, after adding the ZBBridge-U gateway to eWeLink, any scene created through the eWeLink App will also be treated as a Local Scene on the gateway when the conditions for local execution are met.
You can do this by importing all scenes into the device so that they are accessible via the web interface, but with the distinction being made between which scenes are local and which are cloud-based.
It will definitely please you because you don’t always have a mobile phone or working internet at hand. This way, this limitation would disappear with the ultra version and the gate would sell better. It would not be a replacement for iHost as you could only create and edit scenes.
It would also be good if scenes created via the web interface in the gateway were automatically synchronized to ewelink.
