Add #HEX value inputs to Color Picker on eWeLink CUBE
Thanks for bringing back RGB functionality for IKEA bulbs. The bug is fixed in the iHost GUI and CAST, but it’s still present in Node-RED.
Could you please add a text box for HEX values for color, brightness, etc.? It would be awesome to be able to Ctrl-C Ctrl-V values between each bulb. With the current color picker, it’s difficult to clone settings and apply them to multiple bulbs, making scene creation time-consuming. Colors are off too and it’s visible when bulbs are next to each other.
The CAST color picker is fine. Just add text boxes for easy copy&paste in Node-RED and Ihost GUI.
EDIT:
The color picker in Manual scenes is also affected. You can manually choose color in the ihost GUI OR CAST and it renders it properly. But if you choose lets say RED in manual scenes OR Node-RED it gives you watered down, washed, pinkish something. Weird.
Hey,
I’ve turned your post into a feature request so other users can vote & our team can track and collect more relevant feedback.
Thx
For the problem regarding RGB setting in manually scene.
Did you try reset the RGB in the manually scene?
The problem might due to old scene data, just need to refresh it.
For the node-red plugin update.
We’ll evaluate it frist and get back to you soon.
