Access to logs for shared users
Hello!
Is there a possibility to restrict access to device log for shared users?
Thank you very much in advance.
-Edijs
How did you set the sharing so that someone other than the admin can also see the LOGs? It doesn’t work for me and I have set it to the maximum possible, but then again, even an ordinary user can easily delete and not only the timers, but can also delete the device itself, which I can’t remove again (that seems quite strange to me). Sharing options are quite limited.
As an Admin, I also have the following against other users:
Current version… (firmware update)
Share
Create group
Push notification
Offline alert
Logs
Power-on State
Inching Settings.
