Unable to configure inching setting on ZBMINIR2
This happened after updating to 2.6.2
Yes.
If I confirm that in my case with i-HOST 2.6.2, the auto-shutdown mode (inching mode) on the devices ZBMINR2 (v. 1.0.4) doesn’t work:
It does not allow to change the duration and deactivate/activate the inching mode. Refresh browser change status of inching mode, but change the duration don’t work.
And the same issue with S60ZBTPF (v. 1.0.2):
It doesn’t allow changing the duration or disabling it. S60ZBTPF doesn’t work.
It is a serious problem that renders all the aforementioned devices inoperative and should be resolved as quickly as possible.
Greetings
Adolfo Rupérez
We have verified and identified the issue you reported. We will be fixing this problem in the next version, v2.7.0, which is expected to be released around the end of August. Thank you for your contribution!
Ok. Greetings
eWewlink cube v2.7.0 update did not fix the problem with the ZBMINIR2(1.0.4) device.
The device freezes. You need to unplug the device to restart it.
Yes, we have just replicated the issue, and our development team is currently working on addressing the root cause. Sorry for the inconvenience caused!
We will address this issue in the October update. We apologize for the inconvenience it has caused you. Could you please let us know how urgent this problem is for you? If it’s urgent, we can explore other potential solutions to resolve it.
Thanks for the information. As for me, I can wait until October.
And me too
