The 3.7.0 NSPanel Pro firmware needs urgent revision
…and then the fact that the devices paired in NSPanel Pro do not synchronize while those in the Zigbee Bridge Ultra do…while before the releases 3.7.0 in NS Panel and 2.4.1 in iHost it was all possible… :frowning: @ward
Hey
Paral-sync needs updates to work with NSPro’s new API, which is planned.
If it worked before and then stops working after an update, what do we say to guests of a hotel that has a home automation system that works sometimes yes and sometimes no?
Do a survey with those who want STABILITY before NEWS FEATURES :wink:
Maybe save the brand name?
I suspect that we will never see a stable version of the Nspanel pro device.
The device was poorly designed. As always, a lot has been promised, but technically it is difficult to deliver.
Nspanel pro is still a beta version of the product.
Yes, I’m using web shortcut features to show CAST and home assistant dashboard. After restore and the 3.7.0 was installed directly, I have no problems anymore.
The NS Panel Pro stops freezing.
I tried this but still seeing hangs and crashes on v3.7.0
outch :grimacing:
I guess I had lucky
Bonjour
Jai la version 3.7.0 et pas de bug de redémarrage.
Par contre paramétrage de la fonction thermostat difficile
Have recent plans been changed? This week or perhaps next week?
Hey
3.7.1 should be ready now, which fixes some issues we identified.
Thank you. You mean that one can already try to download this update?
Yes, I just installed it.
Issues related to the HA webpage, screen timeout, and external temperature sensors of TRV should be fixed.
The version also fixed an issue where scenes with certain thermostats as triggers wouldn’t execute.
Downloading right now. Will let you know about experiences when completed and restarted.
Do you know about Zigbee, screensaver and web shortcuts issues? Have they been addressed as well or is this the future song?
Other issues we can restored will be fixed in the next version, but I think screensaver and shortcut issues should be resolved in 3.7.1.
Screensaver appears to work as expected. The rest is yet to be experienced :slight_smile:
Is this release note correct? Looks like 3.7.0
It’s not but the version is definitely 3.7.1. In the heat of creation they forgot to update accordingly :dizzy: Just be so nice and let it go :slight_smile:
Heheh, sure. I don’t mind. It was just to raise the flag in case they need to fix it and haven’t noticed :slight_smile:
@ward
The revised firmware has been in place for several days. So far, I haven’t noticed anything worrying. The unfortunate stumbles and omissions have been removed, or at least it seems so. Some views (screens) have not been corrected. Here and there the descriptions are incomplete (truncated).
Overall, the interface needs to be rethought and tidied up. Some controls are in Device Settings and some are on the home screen (e.g. Gateway). Not very logical. By the way, someone please explain to me why the Split Screen option is called as it is now. What does it have to do with splitting the screen?
