Temerature trigger in decimals
Please add temperature set in decimals like 22.5 or 23.8 to turn off or on the device.
Now is only 21.0 22.0 23.0 …
Thank you
Perhaps the sensors are not accurate enough to do so, may I know the device ID of your sensor? @natalia.long please check with the dev-team.
The device is Sonoff SNZB-02 ZigBee Temperature and Humidity Sensor
ID of my three sensors:
a48000317f
a48001d031
a48001d036
In app it show decimal temperatures like 22.3 , 23.6 … but when I want to select it for scene trigger it says: Please enter a number
Thank you
hi, any news about that issue? thank you
I think it’s an issue that needs to be fixed, the data accuracy in the scene and device pages should remain uniform.
However, sensors have quite different accuracy.
Have the same problem. Temperature sensors do show the data with decimals, but scene triggers seems to be buggy.
I have the same problem with TH16+Si7021. In the Auto mode I can use decimal temperatures but not as a scene trigger.
This is something that definitely needs to be fixed.
Thanks,
André
