Hi.. The probe of ( Temperature Sensor Power Switch TH-20) as per attached photo is taped on the external metal body of Water Heater Tank ( by extending the probe wire). This way to get Water Tank Temperature to be displayed on ewelink app (& to know when we can take a hot shower). The Water Tank Temperature is noticed to go to a maximum of about 70.5 deg.C.. However, when registering TH-20 as Thermo Plugin (with purpose to be able make scenes using TH-20), the issue ewelink has a Cap of 60 deg.C !!. Wheres as the actual Temperature goes to over 60 deg.C. This causes the TH-20 to turn itself off since Temperature has already reached beyond the Cap (60 deg.C). So, please update ewelink Thermo Plugin Temperature Cap to become at least 75 deg.C or above (instead of a Cap of 60 deg.C).
Thanks for the good work..
