SONOFF ZBMINI - REVERSE LIVE/NEUTRAL WIRES
Hi everyone, on a light point I need to interrupt the neutral instead of the live. If I reverse the connections of the ZBMini (live in N and neutral in L IN + neutral to the lamp in L OUT) everything works fine. However, I would like to know if in the long run the reversal of neutral and live can damage the Sonoff.
Thank you,
Simone
No, it won’t. I run three switches attached to power cords with flat Europlugs. It doesn’t matter how you insert a plug into the outlet.
You can connect like this. :warning:
You must remember that the output voltage will always be there, regardless of the state of the relay.
