I have been having a problem and now I can reproduce it
I have mini RBS version 1.0.4. if select to open and then I select close at mid point ,then it gets stuck and does not close.only can open. If I open fully and let it there a few seconds,it recovers.
No,i did not find a solution yet! I even notified it on the app with no response !
I only have one device of this kind in my setup and I don’t know if this is a problem of this device or the firmware . Do you have more than one? all of them do the same?
I d’on tunderstand why they can’t fix it by firmware because the device can work both ways.only a pause is needed. Note that I’m talking about software buttons,not hardware.
Anyway,if this can’t be fixed they should recall them or give the possibility to exchange for other models! I did not notice it until it was too late and now I’m stuck with this device .the previous version worked better
