Hi.
I would like to know when we will finally see full or at least better support for scenes on the ewelik web. it still shows unsupported for some scenes. is it possible to at least explain what the problem is?
Can you describe the situation in more detail and show some screenshots?
When i put an action “Notification” in my scene on Smartphone Application, this scene is “Not Supported” on eWeLink Web. ![]()
This symptom usually occurs when some function is not implemented/available on the ewelink web version.
The answer is probably here from StephenJ from February 27, 2025: eWeLink Web V3.12 Update on Jan 16 -- CAM-S2 supported - #322 by StephenJ
eWeLink Web scene do not support the configuration of Push Notification, which is only available on the eWeLink app.
There is no notification for the specified scene, but the device group is not supported either.
What devices are grouped? It would be great if you can provide one of the device IDs.
