Ewelinka’s fantastic function could be the visualization of the value of the analog current signal 4-20mA or the analog voltage signal according to the defined characteristic curve. But you would need an analog to digital interface (A to D) to visualize the data.
Hi there,
I understand that you are suggesting a feature where the values of analog current signals (4-20mA) or analog voltage signals can be visualized based on predefined characteristic curves. Could you please share more about the purpose behind wanting to graph the values of current or voltage signals?
Hi
At that time, I was thinking about a hydrostatic water level probe in the tank of a mobile home (there are probes in 4-20mA current loop versions, but also with an analog voltage signal), but then I thought about e.g. a flow meter but also about transducers of other physical quantities.
Hi, I’m just curious if there has been some progress for this thread? Many sensors of various physical quantities have 4-20mA output and accessing them by means of analogue to digital wifi transducer and customised representation within ewelink app would be much appreciated and useful.
