Which products are supported?
More eWeLink Support devices can be found on IFTTT and a wide range of capabilities are added to the updated eWeLink service on IFTTT.
You may refer to the table below on which devices are supported and what they can do as triggers or actions on IFTTT.
Is there an updated list available?
I have a Power monitoring device that has full eWelink Application support(Mobile/Cast and Web). However it does not get picked up on IFTTT as a compatible power monitoring device. Where would the dependency for this implementation be, the device manufacturer, eWelink or IFTTT?
The device in question below.
Hi there, could you please send the device ID? So that I can conduct a quick check
Devices both on version 3.5.0 and ids below
100169165b
1001690df8
I have SONNOFF B05-BL Wi-Fi Smart LED Bulb which are not showing in IFTTT “Set color for light” create action form. I am getting “No options available”, although they are defined and working normally from the dashboard, alexa and webhook, except for IFTTT.
