Node-red to control a meross mss315 device locally
Hello colleagues. I need help. How to configure a flow in Node-red to control a meross mss315 device locally. If possible, please provide a ready flow.
I don´t have a Meross plug, and ignore its capabilities, but I assume it will be local, Matter, as is this Sonoff S60 wifi plug that I have. The flow for switching is an inject node that can be edited on/off while the energy values are retrieved using an inject node and saved to context and a debug node. I don´t know what you want to do with that, neither how you want to control but these will need wiring into your automations. Hope it works for the Meross,
flows.json (6.7 KB)
