Hi there,
I’ve put together a flow in Node-Red but hit a snag with the final trigger – it’s a bit of a head-scratcher! I’m pretty sure the switch node is the culprit. The plan? To set up a virtual switch that lets me turn this specific flow on or off at will. But here’s the twist: the flow gets all jammed up at the timers, and I suspect it’s got something to do with the payload from the switch. Got any clever ideas to help out?"
This is the main flow:
The properties of the Enabler Switch
The Switch Node
THE PROBLEM STARTS HERE
