MINI-ZBRBS in Pulse mode requires two switch presses
Bom dia, continuo a ter o medmo problema , não consigo resolver, é mesmo aborrecido ter que carregar 2 vezes no botão para accionar a persiana, para quando uma resolução ?
Hello, thank you for your feedback. We sincerely apologize for the inconvenience this has caused you. We are currently working on other high-priority issues, so the problem you reported has been scheduled to be fixed in August, and we expect to release a new firmware version with the fix in September. Please bear with us in the meantime. We will notify you as soon as the update is available. Thank you for your understanding and support!
Eu tenho o mesmo problema, substitui o MINI_ZBRBS pelo MINI-RBS (matter) e ficou tudo ok, o mini-ZBRBS tem problemas de firmware continuo a espera do update para Setembro (informação dada pela ewelink). Tenho também um equipado com o DUAL R3 que trabalha bem sem problemas.
Hello, I hope that the fact that three quick button presses cause the device to disconnect (both the grandson and the wife can handle this perfectly) will also be fixed and it will have to be paired again, renamed, assigned to a location, shared again, and the logs will be lost. Only inactive scenes will remain, but they will remain off even after re-pairing. I wanted to order another ZBRBS, but now after the frequent disappearance of the device, I will wait for the repair and then I will see. It is not bad that you do not have to remove button for the re-pairing device, the bad thing is that the paired device one disappears. How about changing it to at least 5 presses?
It’s been almost a year since I created a post with these problems, today I mounted it again removing only one of the Dual R3, if I had read this post before I would have saved the work.
Everything remains the same, only it has changed that now the engine stays energized for 2 minutes, when it came out it stayed 24 hours a day.
Everything else remains the same, it does not respond to the pulses, if I raise the blind and I want it to lower it a little it does not, I have to press several times and it stops going down, you do not know if it will respond or not to the pulses.
It makes no sense that something that is wired does not work when pressing, it is as if the wired button sends the signal to Hawaii and returns to respond :person_facepalming:t2:
Why haven’t they solved this in a year?
Do the same as in the dual R3 I just want to have everything zigbee, use the same firmware and everything is fine.
Another problem, if I’m going to install it in the app I find it I change the name the calibration poster comes out and zas! The device doesn’t exist, I look and it’s blinking, incredible.
Like this over and over again until it worked.
An hour later, the lower temperature scene is activated outside the street, open the blind and it doesn’t work!
I go to the app and it doesn’t exist!
The LED flashing :person_facepalming:t2:
I’ve already removed it, thank goodness I didn’t change them all.
I don’t understand why they don’t fix any device even if it doesn’t have a connection, it responds to pulses.
This one doesn’t!
When the blind is opened or closed, it stays running for 2 minutes! Unbelievable, what is the calibration for if it’s going to be in motion for two minutes :man_shrugging:
It doesn’t matter if you do it manually or automatically, it doesn’t pay attention to you, it will keep the blind running for 2 more minutes!
The day a final race fails, it will destroy the blind, keep that in mind.
All this does not happen with the Dual R3, once calibrated the person stays in motion for 1 second or 2 seconds, like all the ones I have used, it is calibrated perfectly.
I don’t know why after a year they have only changed the time from 24 hours a day to 2 minutes, why didn’t they put only 1 second?
I repeat it doesn’t make any sense, I read that a Sonoff technician said it was so that it was calibrated, I have the Dual R3 for many years, I never calibrated them again!
Just by opening the blind 100% once, it does it every day at dusk or dawn depending on whether it is summer or winter, so it continues perfect years, it always stops at the same distance, either if I ask Alexa 50% or 20% always in the same place it stops.
The pulsations are instant, it does not disconnect.
Please fix it, I’m calm because I returned them all and this time I only bought one, I’ll keep it and I’ll try it again next year :joy: it’s for fun I’m sorry.
Hello, thank you for your detailed feedback. We sincerely apologize for the unpleasant experience.
Regarding the issue you mentioned where the device repeatedly “disappears” from the app, to help our technical team investigate further, we would like to ask you the following:
  • Which gateway are you currently using—ZBBridge‑U or another model?
  • Does the disappearance follow any pattern? For example, does it tend to happen after certain actions such as calibration, renaming the device, setting up scenes, or triggering automations? Or does it occur completely at random?
Thank you again for your understanding and patience.
Hello, thank you for your additional information. We sincerely apologize for the unpleasant experience. To help us more accurately determine whether the device disappearance issue is related to this scenario, we would like to ask you to provide a detailed description:
  1. What exactly did you do before the device disappeared? For example, did you press the button three times, or did you perform other operations in the app (such as calibration, renaming, setting up scenes, etc.)?
  2. How often does the device disappear? For instance, does it happen every day or only occasionally? Does it occur more often after a specific action?
  3. Which gateway are you currently using – ZBBridge‑U or another model?
Thank you for your patience and cooperation. We will continue to follow up on this issue.
Hello, so I use ZBBridge-P and the removal only occurs when I press the control button three times quickly. I didn’t know how my wife or grandson managed to do it until someone on the forum pointed it out to me and it really is and it works, it’s good if I want to pair the device, but if it’s already in the application, the device is deleted and the history only remembers the scenes, where the device returns to, but the previously turned on scenes still remain turned off.
Hello, thank you for your feedback. I have documented the issue you mentioned where “quickly pressing the control button three times causes the device to be removed” and forwarded it to the relevant team for evaluation and handling.
Thank you again for your detailed description and patience—this is very helpful for us to improve our products. If you have any other questions or suggestions, please feel free to let us know.
Hello Minnie,
I’m using the ZBBridge-U, and I can also confirm that the switch unpairs when the button is pressed repeatedly. However, as someone else has already mentioned, I suspect that unpairing also occurs when I set up a scene with the SNZB-02P thermometer (to close the blinds when the temperature is exceeded).
I’ve also noticed that the EWELINK app is missing the following configuration options, which are common on other Zigbee devices:
  • Network indicator - on/off
  • Pilot function - Turbo mode (increase signal strength)
Thank you for your help Jan
Hi DJackCZ,
  1. Do you mean that after pressing the external switch three times, the device enters pairing mode, or that it disconnects from the ZBBridge-P and can no longer be controlled?
  2. Could you please let us know what type of switch you are using (Rocker Switch or Momentary Switch)?
  3. Is the device currently in Pulse Mode?
  4. What is the firmware version of your MINI-ZBRBS?
  5. What is the firmware version of your ZBBridge-P?
We’ll arrange testing and fix this issue immediately.
Hi @Leung,
Yes, summarizing what people have been reporting here for the last 6 months :
  • MINI-ZBRBS impulse mode has been bugged from release : two button pushes are required when it is manually controlled. It’s a module firmware issue from design an doesn’t depend on the gateway (it behaves just the same when the Zigbee gateway is powered-off).
  • Because MINI-ZBRBS does not react to a single press, users press it again. If they do so three time in a row, the module enters pairing mode and disconnects from the gateway.
Please find all details in the first post in this thread.
I use scenes with the SNZB-02P, but I didn’t notice that they were scenes. They normally worked at 25-27°C at 40% and above 27°C at 64% in the period from 10-18 hours, then on their own as needed.
  1. it disconnects, disappears in eWelink and there is no way to control it (except for the buttons on the wall :grinning_face:)
  2. momentary switch
  3. I have it as Edge Mode
  4. 1.0.5 plug-in 1.0.23 and FW name SN-MG21-ZBRBS-01
  5. 3.4.1 and FW name SN-NG-ZBP-01
This issue has been confirmed to be on the sub-device side and has already been reported to the product manager responsible for MINI-ZBRBS. It’s now on the roadmap for a future update. Once the upgrade plan is finalized, he’ll provide an update here.
Thanks everyone for your feedback!
Hello Jan,
Thank you for your feedback – it is very helpful for our troubleshooting.
I would like to clarify a few points regarding the issues you mentioned:
  1. Regarding the issue where the switch unpairs when the button is pressed repeatedly:
    After how many presses did the unpairing occur? Is it a fixed number of presses, or does it happen when you quickly press the button three times, as other users have reported?
  2. Regarding the unpairing issue after setting up a scene with the SNZB‑02P thermometer:
    Does this happen frequently, or only occasionally? If possible, could you please provide a screenshot of the automation scene you set up with the SNZB‑02P?
  3. Regarding the missing configuration options in the eWeLink App (Network indicator – on/off, and Turbo mode):
    Which device are these options missing on? Is it the ZBBridge‑U gateway itself, or one of its sub‑devices (e.g., the SNZB‑02P or another Zigbee device)? If possible, please provide the device model and device ID for that device.
Additionally, could you please provide the device ID of your ZBBridge‑U, and submit the logs via the eWeLink App? To do this, go to “My” → “Problem Feedback”, select the corresponding ZBBridge‑U device, and make sure to check the “Upload logs” option. Our technical team will then be able to investigate further using the system logs.
The information you provide will help us pinpoint the issue more accurately. Thank you again for your patience and cooperation!
Hi Minnie,
  1. I’ve been running repeated tests on putting the MINI-ZBRBS into pairing mode, and here are my findings:
  • “External Switch Mode – Pulse Mode” must be selected
  • The MINI-ZBRBS repeatedly unpairs after several very quick, short presses of the same button (I tested the “up” button). However, I’m not entirely sure if it happens exactly after 3 presses, because it depends heavily on the duration of each press and the pause between them. The press must be long enough for the MINI-ZBRBS to accept it, but short enough for the MINI-ZBRBS to unpair.
  1. I’ll try to reproduce the issue
  2. The network indicator setting on/off and Turbo mode are missing on the MINI-ZBRBS (the eWeLink app doesn’t offer this option in the menu for me)
Best regards, Jan
GW: ZBBridge-U
It happens when I add it to the app once I find the device I press it to change the name and an error message appears, I look and it is not in the list of added devices and the LED starts flashing in pairing mode.
I repeat it again and I already add it, it appears to calibrate and the same thing happens again.
Sometimes it’s the second attempt or the third never the first attempt.
Then it doesn’t matter how he calibrates it, he will always leave the device running even if it is 100% for 2 minutes.
If you press down the button does not respond, you have to press it again until it works.
If it is going down or up or stopped, it does not respond to the pulse or does so with delay.
All this happens with those I bought and with the one that the technical service sent me.
I don’t understand why the physical button is not instantaneous, like the dual R3 or any other, the pulses are detected instantly.
It has a delay to stop when it was going down or up.
I hope they fix it, personally I don’t think they will, maybe a new version, but this one has some defect, I think it doesn’t have consumption detection that’s why it stays 2 minutes after 100% if it had consumption detection like the R3 it would stop instantly when it reaches 100%.
It’s been a year since everything happened and I see that they only changed from 24 hours in progress to 2 minutes.
I read the same problems, after a year, it makes me understand that it is the hardware.
I hope I’m wrong, I thought it would already be solved and I bought them again, I will wait as long as possible to return them all and I will only keep one so as not to make the same mistake three times.
It’s a shame, it’s the only thing I don’t have for zigbee and the fire detectors it’s weird that you don’t have any yet.
It seems that’s why it goes into pairing mode.
Since it does not respond to the stop pulsation when it goes up and down and I pulse it several times, until it stops.
I don’t see the app at that time and hours later the scenes don’t work and I see that it’s in pairing mode.
Now I understand what happens to me by pressing the down or up button more than twice to stop the blind.
I thought it was just put on pairing mode.
Thank you for confirming it, they need to solve it, I repeat if in a year we all continue with the same problems this will be hardware too, it makes no sense that it does not respond instantly to the physical button that goes directly to an entry of the esp32, it is very rare, as if the press went to the cloud and returned :man_shrugging:
Thank you very much for your detailed testing and feedback. Regarding the issue where the button requires multiple presses to respond, we have identified the root cause, and a fix will be included in a new firmware release no later than the end of September.
