Looking for Zigbee bulb
I am looking for zigbee bulb with high brightness 1000 Luminous or higher, coulor changing and dimable. Similar to B05-BL-A60. Please suggest which bulb I can select. I have i-Host would like to have this managed on my i-Host.
I just found this on AliExpress: CZK259.94 | Ewelink E27 15W 18W Zigbee WiFi LED Light Bulbs RGB CW AC 220V 110V Works With Alexa Google Assisatnt Yandex Alice Home Decor https://a.aliexpress.com/_Eygcm7c
Thanks for the effort, however the reviews are not encouraging and Qty availble are less as compared what I need. I will keep track.
Will ask itead.cc for more Qty.
Purchase a zigbee bulb holder instead
That is a good idea, however I will not be able to change colour or dim the bulb.
you can try those, are rated at 950lm, close to your need:
They also work on ewelink and Tuya in case you want to reuse in other application
Hope this helps.
Thanks I will check it.
